Locked Topic New folks that need help on identifying parts (Read 4578 times)
Rob Valdez 79 R65
Junior Member
08/03/08 at 22:58:45
There are no actions to perform.
This is a valuable tool that every airhead owner should have at the TOP of his bookmarks/favorites.
http://www.realoem.com/bmw/select.do
type in your 7 digit serial number found next to the oil fill hole on the engine block.  That will take you to the fiche you need for that engine (hopefully your engine and frame #'s match.
BOOKMARK THIS PAGE!
It will be your friend for life.
I was compelled to write this by the recent queries about some parts.
We in R65-land are lucky in that we only have 3 major changes during the 15-odd year run of the R65 engine.  Owners of the big-frame have a lot more headaches!
« Last Edit: 08/24/08 at 20:06:34 by Rob Valdez 79 R65 »
redzap
Ex Member
Re: New folks that need help on identifying parts
Reply #1 - 08/04/08 at 19:49:33
Rob,  Thanks for the link.  Interesting.  I find that my R 65 was manufactured in 12/83.  The engine number is located on a polished surface on the left front of the engine, not near the oil filler hole.  This is what they started to do in 1984.  Also, the frame and engine numbers do not match even though I was pretty sure the entire bike/package is original as I know its history of ownership.  If you can give me any info on this, it might qwell my anxiety.
nhmaf
Global Moderator
Free at last, Free at
last!
Reply #2 - 08/04/08 at 21:43:09
I think that it was around the 84 model year that they stopped putting the engine number over the oil plug location, if memory serves.
Your bike's mfg date of 12/83 identifies it as a 1984 model - in Germany the production runs for a model year went from September of the prior calendar year until June/July of the model year, then the factory closed down for August holiday (like most of Europe), and they would
start building the next model year's bikes when they returned from holiday sometime in September.
Rob Valdez 79 R65
Junior Member
Reply #3 - 08/24/08 at 20:04:16
bump
StanG
Ex Member
Reply #4 - 01/07/09 at 06:44:30
As a newbie thanks for this link.
NC Steve
Reply #5 - 01/07/09 at 07:27:37
And for other assorted parts as well as historic/statistical info and specs, check out these sites also.
http://www.maxbmwmotorcycles.com/fiche/MainDiagrams.asp?mospid=47851
http://www.bmbikes.co.uk/index.htm
00 Guzzi Jackal, 89 Guzzi Mille GT
