Page Index Toggle Pages: 1 ... 6 7 [8] 9 10 11 Send TopicPrint
Very Hot Topic (More than 25 Replies) Sprucing up the old R65... (Read 11333 times)
Adrian
Senior Member
The Old Hairy Biker Sez...
Re: Sprucing up the old R65...
Reply #105 - 10/13/16 at 05:53:02
Having got sidetracked into making a new backrest pad I finally started on the seat tray. Here is the thing with all the paint removed and a gentle rub over with some very fine wet/dry paper. Soon to be black - once the weather improves for spraying Smiley
1984 R65 (860)
Adrian
Senior Member
Reply #106 - 01/22/17 at 22:26:16
Okay finally the resto is back on track - So even though it gets to 40 degrees C sometimes - I'm back in the shed at last. What's that about mad dogs and Englishmen????
The new lift tray is great - here's the start today of the sub assembly attached back to the frame - no bending down any more - woohooo
The other picture is the centre stand attached - but my first problem has arrived.
How do I attach the springs to the Centre stand and frame? I have given it a quick try with bent nose pliers - and that wasn't very successful.
So any help is going to be very much appreciated thanks   Adrian
1984 R65 (860)
Adrian
Senior Member
Reply #107 - 01/22/17 at 22:26:47
The spring .......
1984 R65 (860)
Adrian
Senior Member
Reply #108 - 01/22/17 at 22:28:40
And why is it only possible to post one picture at a time now???
1984 R65 (860)
Chris S
Reply #109 - 01/23/17 at 10:29:02
Looking like some nice work Adrian.
Not sure about the issue of one image at a time, I had some issues with this a while back, but it may have been me not the forum! Check out that thread, it might help.
1981 R65
Adrian
Senior Member
Reply #110 - 01/23/17 at 21:19:44
Panic over - I saw a photo of a spring puller on another forum - so this photo is my version - a large set of mole grips and a very small allen key I found in the bottom of my tool box - suitably bent.
The spring was so easily stretched and went onto the small ring on the centre stand with no problems whatsoever.
Sometimes I surprise myself  Grin
1984 R65 (860)
Chris S
Reply #111 - 01/24/17 at 02:14:38
It's great when you get help and then fix it yourself!
1981 R65
Adrian
Senior Member
Reply #112 - 01/24/17 at 06:17:16
Chris S wrote on 01/24/17 at 02:14:38:
Thanks Chris  Wink
1984 R65 (860)
Adrian
Senior Member
Reply #113 - 02/01/17 at 04:57:01
So a little more has been done - swing arm on - bevel drive and the suspension units too. I forgot to order washers for all the nuts and plugs and filler bolts and all that - derrrrrrr must have had  seniors moment or two.
Anyway thanks to the quick and efficient mob in Western Australia - Munich Motorcycles - I had them today with them arriving overnight - great bike shop and highly recommended
So 2 more pics -
1984 R65 (860)
wilcom
Reply #114 - 02/01/17 at 12:27:44
Looking good, Adrian!!!
1979  R65
1980  R65
1972  R75
1964 R50
Adrian
Senior Member
Reply #115 - 02/01/17 at 17:50:01
Thanks Wilcom  Wink
1984 R65 (860)
Adrian
Senior Member
Reply #116 - 02/02/17 at 02:06:30
I made my own Zinc Plating kit from info I found on the net. This is my test bolt to see how it all goes. Not a bad result considering this was a fully rusted up bolt. Not the brightest star in the night sky but acceptable.
So some wire brushing and then a clean in Isopropyl Alcohol and here it is after two 30 minute sessions. Not bad .....
By the way I did buy a replacement fasteners kit for the bike but some of the fasteners etc aren't included.
The green looking liquid is acid mixed about 75% to 25% water.
1984 R65 (860)
skippyc
Senior Member
Shouldn't have sold them
old bikes.
Reply #117 - 02/02/17 at 22:25:43
Adrian wrote on 02/02/17 at 02:06:30:
Hi What electrolyte did you use? They look alright.
Adrian
Senior Member
Reply #118 - 02/03/17 at 02:14:36
skippyc wrote on 02/02/17 at 22:25:43:
Hi Skippyc - the electrolyte is made from 6 liters of white vinegar - 1 kilo of white sugar and 1 kilo of sea salt.
the zinc rods are plain ol' zinc anodes that can be bought from any decent boating shop. They are usually 99% or better zinc so they make excellent anodes.
Once the salt and sugar have been dissolved in the vinegar put the  anodes ( I use 4 - that's two zinc anodes cut in half) put the anodes in to the liquid for about 12 hours before using.
It works really well ......
1984 R65 (860)
Chris S
Reply #119 - 02/03/17 at 16:28:41
Nice job Adrian,
She is going to look very nice👍
1981 R65
