Normal Topic Airhead Relay Substitutes (Read 1441 times)
montmil
In Memorial
12/19/11 at 18:54:36
From the Airheads Beemer Club Technical Information:
http://www.airheads.org/content/view/159/98/
montmil
In Memorial
Re: Airhead Relay Substitutes
Reply #1 - 05/02/14 at 07:40:11
Original poster has removed/deleted his relay tech article from the ABC website.  Sad
Bob_Roller
Global Moderator
  GMT -7 Hours
Reply #2 - 05/03/14 at 12:34:35
The only thing I will add to other than OEM relays being used, is the starter relay is specific to BMW motorcycles .
There is a diode inside the OEM relay, if you use a relay without this diode, there's the possibility that every time you pull the clutch lever in, the neutral light will come on .
