Normal Topic GEN Light Auxiliary Circuit (Read 1243 times)
montmil
In Memorial
01/16/13 at 12:28:10
Maintaining the GEN lamp is critical in keeping your BMW Airhead's battery charging. In the rare instances should a GEN warning bulb fail, that little bulb's filament will knock out the exciter circuit of the Airhead charging circuit. Bad bulb. No charge.
Here's how to build and install a solid-state alternator back-up for less than two bucks:
Available at Radio Shack, pick up a five-pack of 330 Ohm, 1/2 watt resistors for just over a buck. A bit of wire, shrink tubing and a zip tie completes the shopping list.
Show more
Solder a wire to each end of the resistor leads. I used about one foot each of blue and green/blue as this is the color of the bike's wires you'll tap into. Use a heat sink clip on the resistor leads to protect the resistor from overheating. Cover the soldered joints with small diameter shrink tubing.
Show more
Finally, trim down the zip tie and insert it into the larger diameter shrink tubing. The zip tie stiffener will prevent any potentially damaging flexing of the resistor leads.
Show more
The install is quite simple: The green/blue wire attaches to the green/blue wire terminal on the ignition coil. Attach the blue wire to the blue wire found in that big, white nylon connector block under the fuel tank. That's it. I always feel better if I detach the negative battery cable when ever I'm doing any kind of wiring chores on my Airheads. This circuit is suitable for 1977-95 model Airhead BMWs.
Adrian
Senior Member
The Old Hairy Biker Sez...
Re: GEN Light Auxiliary Circuit
Reply #1 - 03/25/18 at 18:16:36
Hi there - I just wanted to check with you about this circuit. I'm assuming that this is used as well as a light. I have changed to an Acewell speedo/rev counter and fitted a seperate gen light. I would still like to fit this as well - thanks for your advice.....
1984 R65 (860)
marcmax
Any day on two wheels
is a good day
Reply #2 - 03/25/18 at 19:45:19
Hi Adrian,
I fitted an Acewell speedo and a small LED for a GEN light. The LED didn't have enough resistance so I added this mod and have not missed a lick. It has been in place for 4 years now and working perfectly. I did add it to my printed copy of the wiring diagram so I wouldn't forget it is there.
Keep your bike in good repair:  motorcycle boots are not comfortable for walking.
1982 R65ls        1984 R65ls        1991 K75
Adrian
Senior Member
Reply #3 - 03/25/18 at 22:42:31
That's great & thanks marcmax 😉
1984 R65 (860)
Adrian
Senior Member
Reply #4 - 03/30/18 at 23:34:45
Hi again - hopefully the final question - I just wanted to check about the blue wire connection. I don't want to be messing with the 2 wire white connector under the tank - so I plan to connect to the blue wire on the back of the diode board.
As it's the same wire I assume this is okay - reassurance is needed Smiley
It's an R65 1984 model - European spec ......
The surprise for me - was the connection of the resistor. I'm not an electrician but as the gen lamp is connected to the ignition lock (green/black? wire) and the blue wire from the old rev counter plug (I used electrical pins to connect the Acewell to this plug) - I had assumed that the resistor should be connected the same.
I trust that this connection for the resistor must work - but could you explain why it has a different connection to the gen lamp.
Thanks .......
1984 R65 (860)
