Page Index Toggle Pages: 1 2 [3]  Send TopicPrint
Very Hot Topic (More than 25 Replies) Front Forks Maintenance (Read 1632 times)
Tony Smith
Graduate, Wallace and
Gromit School of Engineering
Re: Front Forks Maintenance
Reply #30 - 11/07/18 at 17:31:01
andrewwoodhall wrote on 11/06/18 at 05:40:38:
..the thick plotens..
The pesky  circlip was there, however, languishing in a pile of rust stained gloop.
And it is of the "Seeger" type I mentioned as being a barsteward to fit, and that difficulty is the probable cause of your current "difficulties".
If it is undamaged I'd have a lash at fitting it properly.
Tony Smith
Reply #31 - 11/07/18 at 17:36:04
andrewwoodhall wrote on 11/07/18 at 14:45:38:
to get at the sidestand Allen machine screw head to rebush same.... I feel a new topic coming on.
Having done one recently - good luck.
Do clean out the grease passage and fit a new grease nipple.
At least the post 81 bikes have a readily obtainable bush, the 79/80 owners are on their own as it is NLA and is different to the bush used in /7 machines. Those you get to make yourself. And, if you have a set of bastardised R65 exhaust pipes mated to an R80 engine, you have to cut the bolt and use a half height nut.
andrewwoodhall
YaBB Newbies
Reply #32 - 11/08/18 at 14:47:21
Thanks, Tony.
Back to the forks ----all reassembled, and back on the bike, with front wheel now rotating in the correct direction. lSlight niggle: the initial damping characteristics were not the same in both legs after rebuild, off the bike. I put this down to oil settling into the correct spaces?
Test ride tomorrow, and carb balancing Friday ( the side stand will have to wait).
Current:
Velocette Venom 1957
BMW R65 1984
Past
Honda 50
BSA 250 C15
Honda 90
Velocette Viper
BMW R100 RT
BMW F650
Tony Smith
Reply #33 - 11/08/18 at 15:02:47
andrewwoodhall wrote on 11/08/18 at 14:47:21:
They are very simple dampers, the oil should be more or less fully 'distributed' at first stroke. A difference in damping so large as for you to notice it by hand suggests that you have other gremlins in the system.
Still, if it rides OK, I would not worry too much - if I were to place a bet I'd say that a piece of disintegrated red damper is currently lodged in one of the bleed ports in the damper rod.  If so it will likely deliquesce further over time and the damping rates will equalise.
Barry
Reply #34 - 11/08/18 at 16:03:33
If by any chance you are feeling substantial compression damping on one leg then there is something wrong. The only damping you can easily feel by hand is rebound damping. Compression damping is so weak that it's hard to move the forks fast enough to feel much especially with the springs in.
I test damping by stroking the legs individually without the springs. You should feel rebound damping to be at least 3 times stronger than compression and you should feel rebound damping increase further over the last 1" of stroke at full extension.
andrewwoodhall
YaBB Newbies
Reply #35 - 11/08/18 at 16:30:14
Thanks. Yes, rebound damping is more on one than the other. Compression damping not evident. Hoping for a dry day tomorrow...
Current:
BMW R65 1984
Past
Honda 50
BSA 250 C15
Honda 90
Velocette Viper
BMW R100 RT
BMW F650
marcmax
Any day on two wheels
is a good day
Reply #36 - 11/08/18 at 19:32:37
Darn it Tony. You made me pull out my dictionary. I understand from the sentence what you mean but I have never seen that word and I can't just let that lie.
Keep your bike in good repair:  motorcycle boots are not comfortable for walking.
1982 R65ls        1984 R65ls        1991 K75
Tony Smith
Reply #37 - 11/08/18 at 21:43:49
marcmax wrote on 11/08/18 at 19:32:37:
Sorry, but it describes so well what the red rubber bump stop does. The term is usually used by coroners to describe what (for example)  a body sealed in a plastic bag with a few litres of Hydroflouric acid does.
wilcom
Reply #38 - 11/08/18 at 22:45:55
Tony Smith wrote on 11/08/18 at 21:43:49:
Tony , it was the perfect word. The fact that you could reach out and use it keeps us in awe. You guys and the Brits really have a command of the language. We in the West just fumble along in 3rf-4th place
1979  R65
1980  R65
1972  R75
1964 R50
andrewwoodhall
YaBB Newbies
Reply #39 - 11/09/18 at 07:29:04
Successful first forks renovation  ride this morning; no squeaks or rattles on a sinuous,  rural route. Stopped outside Sharpness docks to do an initial pilot adjustment, followed by further balancing back home. Raining now.
As a bonus, I found both exhaust spider nuts easily removed, so side stand rebushing next job.
Many thanks to all who helped me understand and fix my forks.
Current:
BMW R65 1984
Past
Honda 50
BSA 250 C15
Honda 90
Velocette Viper
BMW R100 RT
BMW F650
