Very Hot Topic (More than 25 Replies) brake swap ? (Read 2666 times)
guyom
Junior Member
brake swap ?
05/30/16 at 13:04:07
Hi guys, I've got problems with the brakes (double disc on R65LS) and want to change to modern brakes. Any ideas of models that do not ask for many modifications on the bike ? Stay double or go to single disc ? Thanks for time
Guyom
Tony Shaw
Full Member
Anymore than two cylinders
is greedy!
Re: brake swap ?
Reply #1 - 05/30/16 at 17:22:32
What's wrong with them, because the twin disk set up on the LS is pretty bullet proof if you fit braided lines and a decent set of disks. I've got a pair of EBC disks from Motorworks on mine and they make a massive difference especially in the wet.
1981 BMW R65ls - The Bimbo
1981 BMW R65ls - the doner to keep above running.
2013 R1200r
1956 BSA A7 Shooting Star.
Bob_Roller
Global Moderator
GMT -7 Hours
Re: brake swap ?
Reply #2 - 05/30/16 at 17:26:36
I have not heard of any member successfully put other calipers, etc. on an R65 .
A few have tried, but I have not heard anything about a completed conversion .
Tony Smith
Graduate, Wallace and
Gromit School of Engineering
Re: brake swap ?
Reply #3 - 05/30/16 at 18:56:11
Bob_Roller wrote on 05/30/16 at 17:26:36:
Getting there!
I have amassed:-
A pair of matching disc rotors
A pair of Brembo 4-spot calipers from a K-bike
A 17mm Master cylinder kit.
Still to do.
Measure up and have machined a pair of stepped adapters to mount the calipers.
Sleeve my old 13mm master cylinder to 17mm and buy it a new reservoir
Have braided hoses made up.
Confession time.
Since I fitted a braided line to my single caliper F08 I am less enthusiastic about fitting the 4-spots to the R65. In fact, I've pretty much lost interest.
Of the gear I've accumulated, the genuine serviceable rotors would look nice on the R100 and the calipers are good spares to keep for my K-Bike project.
In fact I'd have to say that a stock system in good order, with perhaps the addition of braided lines (In my case I specified a braided line that has a black "rubber" outer cover so that it looks stock) works perfectly well and you would really have to have a serious need to go to more exotic brakes.
Tony Smith
Re: brake swap ?
Reply #4 - 05/30/16 at 18:57:42
To which I forgot to add. I suspect that my experience mirrors that of many who have gone before - if you get the stock system working well, the percentage gain in engineering a "better" solution is more trouble than the gain to be had.
guyom
Junior Member
Re: brake swap ?
Reply #5 - 05/31/16 at 11:35:51
HI guys thanks for answer !
So I think i need to find a Repair kit to  restore the stock callipers... I opened them yesterday evening and saw rust and dust... and they stayed stuck a bit on the rotor... a lot of noise etc...
Anyway it goes to my second question : Where i can buy repair kit for dual disc ? Any suggestion ?
Many thanks for time
Tony Smith
Re: brake swap ?
Reply #6 - 05/31/16 at 11:52:00
Do you have Brembos or ATEs?
guyom
Junior Member
Re: brake swap ?
Reply #7 - 05/31/16 at 12:18:28
This is ATE sorry to forget to mention that !
Tony Smith
Re: brake swap ?
Reply #8 - 05/31/16 at 14:51:43
guyom wrote on 05/31/16 at 12:18:28:
The ATEs will inevitably need new pistons as the manufacturer chose to use chrome plated steel for the pistons and aft more than 30 years the chrome plating will have broken down.
New stainless steel pistons are available at a price, or you can make your own if you have or have access to a lathe.
The seals are available and a suitably sized  "Viton" O-ring  can be substituted for the seal between the caliper halves.
Or you can buy new Brembo or Grimecia replacement calipers.
Tony Shaw
Full Member
is greedy!
Re: brake swap ?
Reply #9 - 05/31/16 at 17:25:37
Motobins do rebuild kits for about 35 per calliper, but I'm sure there will be somewhere in Canada who sells them.
https://www.motobins.co.uk/bmw-parts.php?model=R%20Series%202%20valve%20Twin&bik...
2013 R1200r
guyom
Junior Member
Re: brake swap ?
Reply #10 - 06/01/16 at 10:04:29
wilcom
Re: brake swap ?
Reply #11 - 06/01/16 at 10:16:32
guyom wrote on 06/01/16 at 10:04:29:
HI, I found that which including piston :
$134.95............................OUCH!!!!!!!
1972 R75
1964 R50
guyom
Junior Member
Re: brake swap ?
Reply #12 - 06/01/16 at 10:48:41
yes... if anyone has cheaper... (just because 134$ / each Wink).... cost me 280$ including shipping... that's why i also consider swap to new technologies Wink
wilcom
Re: brake swap ?
Reply #13 - 06/01/16 at 11:06:20
guyom wrote on 06/01/16 at 10:48:41:
I would spend $20 on the rubber parts and reuse the pistons and see what I had. If it didn't work out you can always spend the $300 dollars later.
1972 R75
1964 R50
guyom
Junior Member
Re: brake swap ?
Reply #14 - 06/01/16 at 12:22:41
yes well it's actually 29,95$ par set, need 2 for an LS... plus shipping : 74$.
I will try. Thanks !.
wilcom
Re: brake swap ?
Reply #15 - 06/01/16 at 12:40:39
guyom wrote on 06/01/16 at 12:22:41:
That's still a unsubstantial OUCH considering what you are receiving
I think my quick google returned some BMW "car" prices for ATE brakes. which are less costly
1972 R75
1964 R50
guyom
Junior Member
Re: brake swap ?
Reply #16 - 06/01/16 at 13:34:53
ordered. keep you in touch.
Tony Smith
Re: brake swap ?
Reply #17 - 06/01/16 at 14:45:25
Those are for the single sided (i.e. single piston) ATE calipers fitted to the bigger bikes up to 1980.  They will not fit the ATE opposed piston calipers in the  R65
wilcom
Re: brake swap ?
Reply #18 - 06/01/16 at 17:39:55
Tony Smith wrote on 06/01/16 at 14:45:25:
They will not fit the ATE opposed piston calipers in theR65
my book shows 34 11 1 454 809
1972 R75
1964 R50
guyom
Junior Member
Re: brake swap ?
Reply #19 - 06/02/16 at 08:51:03
Hi guys, here is the calliper (right) same thing on the other side Smiley
D Mann
Junior Member
Re: brake swap ?
Reply #20 - 06/12/16 at 06:23:58
http://etypeparts.myshopify.com/products/ate15-bmw1 These pistons are reported to be the right size.
David Mann
1981 R65
ABC #14407
montmil
In Memorial
Re: brake swap ?
Reply #21 - 06/12/16 at 09:07:16
D Mann wrote on 06/12/16 at 06:23:58:
Flashback 51 years ago and memories of the raunchy XKE Jag that my late father cursed me with as a high school ride. Oh, the horror!
wilcom
Re: brake swap ?
Reply #22 - 06/12/16 at 11:07:38
montmil wrote on 06/12/16 at 09:07:16:
an E-Type in HS!!!! I can't even imagine anyone being that freaking cool OMG
1972 R75
1964 R50
Luca
Re: brake swap ?
Reply #23 - 07/03/16 at 11:06:14
You can get brembo calipers new for about $100 a piece.  Somebody posted a link to the site that sells them a little while back.  It's a Moto Guzzi supplier, but the caliper is the same Brembo as our R65's.
I put new rubber in my ATE's but never replaced the pistons, I just cleaned them up.  All has been working ok.
If I was going to go for a custom performance upgrade, I'd be looking at slotted rotors.
'82 R65LS "Heidi"
The new member map is up and running!  See the sticky under "General Announcements" for details and the link.
Tony Smith
Re: brake swap ?
Reply #24 - 07/03/16 at 16:42:32
wilcom wrote on 06/12/16 at 11:07:38:
Chap I went to High School with had an e-type. The "cool" was somewhat diluted when you saw the holes int he floor and realized that the fuel tanks were shot and it was fueled by a jerry-can strapped to the back of the driver's seat.
wilcom
Re: brake swap ?
Reply #25 - 07/03/16 at 18:36:12
Tony Smith wrote on 07/03/16 at 16:42:32:
Yea, but when Monte was in High School That Jag had to be practically new!!!
1972 R75
1964 R50
wilcom
Re: brake swap ?
Reply #26 - 07/04/16 at 12:37:16
wilcom wrote on 07/03/16 at 18:36:12:
Judging from Monte's profile he was the class of 65". If he had it as a senior, couldn't have been more than 4 years old
1972 R75
1964 R50
montmil
In Memorial
Re: brake swap ?
Reply #27 - 07/04/16 at 15:35:20
wilcom wrote on 07/04/16 at 12:37:16:
Correct call, Joe. High school class of 1965 and college class of 1969. Last October wife and I attended the 50th HS reunion. Big crowd as there were over 1000+ students in my Senior class. Not all made it to the reunion, of course. Some didn't even get out of the 'Nam'
Anyway, my old man went through a "car stage" fueled by some doctor-prescribed, weight-loss drugs. Drugs made him absolutely bat s**t crazy. Uppers. Downers and In-betweeners...
The result was that in high school, I steered not only the Jag but an 1964 Corvette convertible and a Porsche 1600 Coupe... which my younger brother wrecked while I was working the summer as an archery instructor at a Boy Scout camp. Wanted to plant an arrow twit his stupid eyes, I did.
College days and the wheels were on my nickle. Triumph T100C and a string of then-cool Chevys.
Those were the days. Hell, they still are! Grin
wilcom
Re: brake swap ?
Reply #28 - 07/04/16 at 17:02:20
montmil wrote on 07/04/16 at 15:35:20:
OMG I think I'm going to pass out.....
1972 R75
1964 R50
