Normal Topic Recovering seat (Read 908 times)
chrisr65ls
YaBB Newbies
My Cow is my friend! ;)
Recovering seat
01/07/17 at 19:21:34
Has anyone ever recovered the seat of an LS themselves? . I have the cover, just not sure if I should be attempting this myself. Should I use staples? current cover seems to be glued and riveted, or should I just get a pro to do it?
marcmax
Any day on two wheels
is a good day
Re: Recovering seat
Reply #1 - 01/07/17 at 21:00:43
Hi Chris. I have recovered a couple of seats, R65 and LS. It is not that difficult and can be done yourself/ Staples will not work as you need to attach the cover to the metal seat pan. A pop rivet tool is what you need. You can use glue along the edges if you need to but I just stretch the cover and use a series of spring clips to hold it in place while I replace the pop rivets. That allows you to make on the fly adjustments to the cover in case you get a small wrinkle, etc. just release the clamps, pull it tight and re-clamp it before riveting in place. All of the holes in the seat pan should already be there, just stretch the cover, place the metal strips over the edge and pop rivet in place. I am about to install a new cover on a 1979 R65 seat that I am installing on my LS. I will take some pics and post them.
Keep your bike in good repair:  motorcycle boots are not comfortable for walking.
1982 R65ls        1984 R65ls        1991 K75
marcmax
is a good day
Re: Recovering seat
Reply #2 - 01/09/17 at 19:53:38
Hi Chris. Sorry for the delay but here are some pics of the seat cover I just installed. I know it is not an LS seat but the principle is the same and this seat is going on an LS.
Barry
Re: Recovering seat
Reply #3 - 01/10/17 at 15:21:18
I recovered mine in the same way marcmax describes so not much to add. It just takes a little patience to make sure the cover is correctly centred. I was going to say it's not a job I would attempt in winter because the heat makes the cover easier to stretch into place ...but then I see you won't have that problem.
chrisr65ls
YaBB Newbies
Re: Recovering seat
Reply #4 - 01/11/17 at 02:35:21
Thanks for that. I'm feeling a lot more confident now. Can't wait for the weekend to get into it.
Adrian
Senior Member
The Old Hairy Biker Sez...
Re: Recovering seat
Reply #5 - 01/25/17 at 18:58:49
Hi and thanks for this info and pics. I was going to pay someone to do one but I can see that it's relatively easy to do. I bought a pre shaped cover from a company in Canada so fitting should be fine. Great photos I love the use of the clips
R65 1984
Chris S
Re: Recovering seat
Reply #6 - 02/08/17 at 04:35:37
Barry,
Is that the toolbox cover attached to the underside of your seat?
Mine doesn't have that, is it glued into place?
1981 R65
Barry
Re: Recovering seat
Reply #7 - 02/08/17 at 15:14:54
Chris,
It's just a self adhesive foam gasket and that's the original one that I managed to remove and replace after painting the seat base.
It does seal around the top of the toolbox and I guess stops it rattling.
Chris S
Re: Recovering seat
Reply #8 - 02/08/17 at 15:30:59
Barry,
Thanks, I haven't been able to find that in my (now dwindled down) box of bits, Inwill need to make something up.
Chris
1981 R65
