Page Index Toggle Pages: 1 [2]  Send TopicPrint
Hot Topic (More than 10 Replies) Overhauling ATE brake Calipers (Read 1927 times)
twocyl
YaBB Newbies
I Love Airheads!
Re: Overhauling ATE brake Calipers
Reply #15 - 04/02/18 at 04:39:29
LMA
Mrclubike
Reply #16 - 04/02/18 at 20:25:13
twocyl wrote on 04/02/18 at 04:39:29:
That is cool
Does it bolt up without an adapter
Tony Smith
Graduate, Wallace and
Gromit School of Engineering
Reply #17 - 04/06/18 at 18:01:45
Mrclubike wrote on 04/02/18 at 20:25:13:
No. You have two choices, machine the forks or machine the calipers so that they centre over the disc (the bolting centres are OK).
I went some distance down this path and decided that I was not comfortable with machining either the fork legs or the calipers and I intended to make an adaptor to fit the 4-spots I bought.
Then I went a different way and am in the process of fitting a K100 front end to my R65 - although my early K-bike front end came fitted with the later Brembo 2-spot calipers (F09s?) the 4-Spots will bolt straight up unmodified, which sort of solves the problem - if in fact I can be bothered fitting them as the twin 2-spots provide all the braking you would ever want. It will come down to which off my collection of master cylinders is able to be rebuilt at the lowest cost - if 13mm then the 2-spots get the gig, the 13mm master cylinder needs a lot of work I will bore it out to take a 15 or 16mm piston and use the 4-spots.
