Normal Topic Trail Tech Vapor Installation (Read 1034 times)
azcycle
Senior Member
BMW Newbie
03/06/17 at 15:03:21
This is a short write-up of my experience with the Trail Tech Vapor (URL: http://www.trailtech.net/digital-gauges/vapor (and indicator light accessory dashboard) digital gauge, which replaced the non-functional stock BMW speedometer and tachometer gauges.
I asked many questions in a different thread:
http://www.bmwr65.org/YaBB%202.612/cgi-bin/yabb2/YaBB.pl?num=1484450042 And thank you to all who patiently answered my questions. Your advice was very much appreciated!
Everything installed and set up without too many hiccups and overall I am happy with the results. I mistakenly ordered the incorrect kit, which was fine EXCEPT that the engine heat sensor's spark plug diameter was too small for the BMW's plug. So no engine heat sensor on my install. If I were to keep the bike, rather than prep it for sale (sniff, sniff), I'd order the correct engine heat sensor and install it.
You can set up shift points (default to 6,000 and 10,000rpm) which, when hard-wired to the bike (won't work on the battery-only power) two tiny LEDs light up, one on either side of the VAPOR text on the dash. I also found out how to set the Vapor's ODO so it doesn't start at zero. They don't publish it but it's out there in various forums if you search for it. So I set the new Vapor ODO to match what I thought was the most accurate mileage, based on the last known mileage from the original gauge and how much both my father-in-law and myself rode it. Not perfect, but it'll be close.
I mocked up a new dash bracket and had one of my more metal-manipulating inclined friends whip it up for me. It isn't too creative, and he was off on some of my measurements a bit, but it was cheap and it works. The new bracket took into account mounting the vapor and indicator light cluster, as well as the ignition and the charge light.
My soldering experience certainly improved by the end of the process. I did hard-wire the Vapor to the battery (rather than have it run just on it's battery).
The biggest hurdle I had to overcome was the placement of the wheel sensor and the magnet. Because my bike has the dual front discs, placement was difficult. Between the fraction of an inch of space between the discs and the fork lowers, and the location of the calipers, there was only one spot I could mount the sensor.
My first attempt at placing the magnet was to glue it flat on the inside of the wheel hug, right at the inside edge of the disc brake. This put the magnet at the top edge of the sensor. I couldn't move the sensor up any further because I wouldn't be able to zip-tie/secure it due to the brake caliper and the lack of clearance between the fork and the disc. I didn't trust the double-sided tape they included with the sensor and the last thing anyone would want is the sensor coming loose and wrapping up into the wheel.
On my test run, my speed was showing at least triple what I was doing, and my two-mile ride showed over 6 miles on the new odometer. According to Trail Tech, that showed that the magnet was not passing the sensor like it should. I even tried to double the wheel size in the settings (which they recommended) but that was way off, as well. They recommended that the middle of the magnet pass the bottom edge of the sensor.
Back to the drawing board.
I went out and purchased a small length of 1/8" thick, 1" wide stainless flat stock and proceeded to cut, drill, and beat a bracket into shape. (Constantly wishing I had a better shop with more tools!) But, I managed to end up with something that wasn't too ugly.
This bracket was bent into a simple stretched "U" shape, with an appropriate hole drilled in each end. One side attached to the hub using one of the hub bolts. The other side held one of the included magnet bolts that came with the Trail Tech. I was able to bend and "fine tune" the bracket slightly so the magnet crossed the bottom of the sensor just perfectly. And I think because the bracket rotates so close to the axle I don't think it affects the balance of the wheel... at least I couldn't feel it.
Ugly bracket before I cleaned it up a bit:
But you can see it ensures the middle of the magnet passes through the bottom edge of the sensor.
The bracket made tightening that hub bolt a little tricky but I eventually got it snugged up nice and tight. I reset my wheel size in the Trail Tech, and double-sided taped my iphone to the fuel tank. Pulled up my handy map app that shows speed via GPS and took the bike out for a spin. The Trail Tech was EXACTLY accurate to my GPS so that was good to go!
« Last Edit: 03/07/17 at 10:02:56 by azcycle »
Graeme Hunt - Tucson, AZ
My 1981 BMW r65 r65 Photos
WWW
azcycle
Senior Member
BMW Newbie
Re: Trail Tech Vapor Installation
Reply #1 - 03/06/17 at 15:07:14
Hit the maximum character count, it seems!
Continued...
The Trail Tech LED indicator dashboard comes with four spots and a variety of lenses. I chose the combined turn signal, high-beam, neutral (which is when I found out my neutral switch was bad!) and oil pressure.  For the charge light, I mounted a larger incandescent bulb below the dash.
I also followed their instructions on how to wrap the RPM wire around the plug wire and think the RPMs shown are pretty accurate. It jumps around a tiny bit, which indicates I should unwrap the wire once or twice, but I'm not going to do that at this point.
My biggest disappointment, and it seems it's a common complaint, is that the LEDs can't be seen during even remotely bright days. The lenses Trail Tech send are way too dark, and the tiny LEDs supplied are just not strong enough. At night, they're great! But during the day... nope.  So I need to purchase some stronger LED bulbs.
That's about it. Hope someone might find this helpful.
« Last Edit: 03/07/17 at 10:03:33 by azcycle »
WWW
Adrian
Senior Member
The Old Hairy Biker Sez...
Reply #2 - 03/07/17 at 02:17:48
Love it azcycle but non of the photos are showing mate ......
1984 R65 (860)
azcycle
Senior Member
BMW Newbie
Reply #3 - 03/07/17 at 09:57:33
Adrian wrote on 03/07/17 at 02:17:48:
Strange... I reworked them so hopefully they show up for you now.
WWW
wilcom
Reply #4 - 03/07/17 at 13:08:58
They came thru to me
1979  R65
1980  R65
1972  R75
1964 R50
YaBB Administrator
I love my Beemers
Reply #5 - 06/04/17 at 17:40:13
I can see them fine, too.  I didn't have the problems you had, strange...
This is what I wound up on the Junkyard Dawg - the little panel under it was from an R1150RT...
WWW
