Normal Topic Front footpeg rubbers (Read 374 times)
Adrian
Senior Member
The Old Hairy Biker Sez...
12/29/17 at 22:53:44
Hi again - I'm trying to fit new rubbers to the front footpeg. They are proving to be impossible. I've tried heating one up but not so hot I can't touch it. Then using a rubber mallet I've tried to knock it on. It's not working. Any ideas please.... Thanks
R65 1984
Barry
Re: Front footpeg rubbers
Reply #1 - 12/30/17 at 03:53:08
Some form of lubricant is needed. In principle anything that will not harm the rubber and eventually flash off.  I'm sure I've heard of using strange things like hairspray.
Bob_Roller
Global Moderator
  GMT -7 Hours
Reply #2 - 12/30/17 at 07:27:07
Window cleaner works well on rubber parts like this, handgrip rubber as well .
BPT
Reply #3 - 12/30/17 at 16:23:19
Also rubbing alcohol.
Rob Valdez 79 R65
Junior Member
Reply #4 - 01/02/18 at 17:01:27
I don't know how fast it would go away, but spray silicone lubricant.
I learned the miracle of that stuff the first time I had to put a bank of carburetors on a Japanese multi.  4 rubber tubes at once...
Tony Smith
Graduate, Wallace and
Gromit School of Engineering
Reply #5 - 01/02/18 at 18:00:07
First I'd try metho (methylated spirits - alcohol to others) ad if that didn't work I's buy some PBR rubber grease used in brake cylinder and master cylinder assembly.
I do remember having a dogged fight with them (at the time I didn't know about metho and i didn't have rubber grease) until I thought to use compressed air - that worked a treat, use a fine "dust gun" inserted under the edge of the rubber and let fly, the air will both expand the rubber and "lubricate" it whilst you ram it home.
Adrian
Senior Member
Reply #6 - 01/02/18 at 19:32:25
Thanks everyone 😉
R65 1984
Barry
Reply #7 - 01/03/18 at 04:57:54
One thought, you don't want them to stick or glue on in any way as when they wear a 180 deg turn will bring a fresh face to the top.
Burt
Full Member
Reply #8 - 01/10/18 at 03:50:29
Vasoline/white petroleum jelly.  Silicone lubricant as well.  If none at hand then any grease should work.
Black 1984 R65 - the Wombat
