Runninn1 wrote on 02/09/18 at 08:18:00:
Finally had the driveshaft pulled and one of the bolts had disappeared that held the driveshaft in place! Lucky??? I found it inside the driveshaft (D/S) swingarm. Anyways, should I use Loctite Red to hold the D/S to the back of the tranny?
No you should not!
What you should do is buy 4 new bolts and throw the ones you have into the bin. If you do not already have a "crows foot" adapter for your torque wrench, get one of those too. Remember to set the crows foot at 90 degrees to your wrench and then after carefully cleaning the drive flange, insert the bolts DRY and torque to the correct figure.
These are "torque to yield" bolts and should only be used once.
Also, the drain bolts on the rearend are stripped, will helicoil be the best option? I am humbled once again....
You should really have these welded up and then drilled and tapped, but that is an expensive exercise.
I'd use "Keensert" or similar, bearing in mind that the actual length of thread will mean that you have to cut the keensert down.
The good news is that in the interests of sealing you can use as much blue loctite as you want when running the keeensert into your freshly drilled and tapped hole.
There is not much room so you will need to use an intermediate tap to start the threads and then almost immediately swap to a bottoming tap. If you do not already own the gear you are going to need then the cost to set yourself up to fix it is going to cost more than paying a good engineering works (NOT under any circumstances a run-of-the-mill dealership mechanic). Then there is the cleanup so you will need a gasket and seeing as you are there, some seals (full kit from motobins for around $AU40). Whilst a keen home mechanic can renew the main (axle) seals, you need expensive special tools to get the front one out.
Unless you are super keen this is probably a job for an engineering shop, or perhaps an independent specialist BMW tech.
if you are interested, here is some blurb on keenserts
http://www.specialty-fasteners.co.uk/content/doc/lib/1122/completekeensertcatalo...http://www.repairengineering.com/keensert.html
