Page Index Toggle Pages: [1] 2 3  Send TopicPrint
Very Hot Topic (More than 25 Replies) Euro Headlight Switch (Read 1329 times)
BPT
02/07/18 at 09:46:07
I have one of these with the plugs on the end of the harness.  Was I naïve in thinking it was plug and play?  Scouring the net, I'm seeing people talking about changing some wiring but these aren't R65's they're talking about.
On ours, does something need to be changed with the wiring?
And how about the relay?
I remember asking here before about the different options for an on/off headlight.  I guess I thought that if you got the proper switch, the switch took care of the wiring differences but now I'm not sure.
          Thanks
Matt Chapter
<insert witty remark here>
Re: Euro Headlight Switch
Reply #1 - 02/07/18 at 10:56:14
On my monoshock, I've replaced the left hand switch assembly (twice!) with the euro version.  It's plug and play.  The only difference is an additional switch position to turn off the headlight, which is handled internal to the switch, not in the harness.
I guess the dual shock switches could be different?
BPT
Reply #2 - 02/07/18 at 12:38:31
I'll get on the fiche and see if I can tell if they're different, I have no idea. But it's good to hear yours was a straight replacement.
Maybe another twin shock owner here has done it and will be able to tell if it's the same and easy like yours was.
    Thanks for the reply, that gives me hope.
BPT
Reply #3 - 02/07/18 at 13:15:55
Max's fiche shows a variety of part numbers fitting the later models but only one for mine.  The US version on mine is the same as what fits the later models.
So I'm wondering if that means there might be some difference, maybe not a straight fit on the earlier ones?
Mrclubike
Reply #4 - 02/07/18 at 17:38:01
It is the way the key switch is wired on the R65
You can get a Euro key switch to retain the parking function or use the USA key and switch the green and grey wires but you loose your parking light function
Mrclubike
Reply #5 - 02/07/18 at 17:57:56
here is a close up of the Euro spec Key switch
It has extra positions for the ignition to be switched separately from the head lights
Also It has no relay to turn the headlights off while cranking
But that makes no difference with the key switch used
BPT
Reply #6 - 02/07/18 at 18:20:57
Ok, I'll study these and see what I can absorb.  Right off the bat, here are a couple of questions:
Sounds like the easiest would be keep the current ignition switch, switch the two wires.  How much will I miss not having the parking light function?
Can I keep my current relay no matter what?  When starting with the Euro switch, will it start with the lights on (harder on the battery, I'll assume)?  Or is there something that makes it only work if the lights are off?
Mrclubike
Reply #7 - 02/07/18 at 18:27:56
i cant find a 85 on mono print
If some one has a link post i up and i will look at it
Mrclubike
Reply #8 - 02/07/18 at 18:31:55
BPT wrote on 02/07/18 at 18:20:57:
Just the park lights If you have to park at night just turn the ignition switch off and leave the headlights (but not very long)
Keep the relay and it will shut the headlights off when cranking no mater how the key switch is wired Euro or US spec
Matt Chapter
Reply #9 - 02/08/18 at 09:55:01
I don't think rewiring the key switch is necessary.  The euro headlight switch has an off position for the headlight.  The "headlight off when starter button pushed" feature works fine on mine, because changing the headlight switch doesn't affect the other switches.
I would trace the current headlight switch wiring and see if the connectors match.  If they do, plug it in and see how it works!
BPT
Reply #10 - 02/08/18 at 12:27:40
I am electrically stupid, Matt, so thought it'd be better to ask first.  And because of that electrical ignorance, I don't trust myself to be able to figure some of that stuff out. Especially with the Germans!
I will try to trace the wires.  But with the different switches, relays and stuff interconnected, I thought it best to ask first.  Naturally I want it to work correctly but I'm more concerned with frying something if I try to do it on my own and get it wrong.
As far as the comparison between our models, I still wonder why Max wouldn't show it for mine if it was a straight up fit.  That's when I really thought there must be some reason and I should be sure I knew what was going on.  I don't mind digging around messing with stuff. But with these things I worry about letting the smoke out or, since it deals with the ignition switch, getting stuck not being able to start.
At least now I'm pretty confident I can make it work with MrClu's instructions.  I'll play around with it to figure out the variables unless someone else pipes up who has done it on the same model.
It's going to be a little whIle before I mess with it but I'll post on the results.
    Thanks
tunnelrider
Senior Member
Reply #11 - 02/11/18 at 02:07:02
I had to move my headlight wire to the park light terminal on my twin shock Euro spec key switch.  Losing the park light also made me lose the tail light and instrument lights.  Not sure if this would be the case on US spec twin shocks.
To get the tail light back I tied the park light spade terminal on to the side of the headlight spade with wire and covered it with insulation tape.  Not ideal but it lasted a 3300km jaunt last week.
 1985 Black R65  -  1983 Ducati Pantah 500 - 2001 DRZ400 dirt only
Mrclubike
Reply #12 - 02/11/18 at 10:57:12
You also loose the tail light when in the first position ignition only
I do have my ignition feed and park lights  wired together  on the terminal normally used for the park lights
I assume one would only use this feature if they   needed  to to conserve power
For example charging failure  or needing to get the battery charged back up quickly
Changing all lights to LED is a great improvement for your charging system
It makes high output alternator conversions obsolete
skippyc
Senior Member
Shouldn't have sold them
old bikes.
Reply #13 - 02/11/18 at 16:55:52
I replaced my headlight with a 20w led bulb and i was surprised how much light it throws out.
https://www.aliexpress.com/item/Motorcycle-LED-Headlight-High-Low-20W-2500LM-HS1...
Tony Smith
Graduate, Wallace and
Gromit School of Engineering
Reply #14 - 02/11/18 at 17:27:07
skippyc wrote on 02/11/18 at 16:55:52:
How did you fit that?
Wouldn't this one better fit the standard headlamp? Or have you changed your headlamp assembly?
https://www.aliexpress.com/item/Plug-and-play-led-motorcycle-headlight-H4-HS1-hi...
