Page Index Toggle Pages: 1 [2] 3  Send TopicPrint
Very Hot Topic (More than 25 Replies) Euro Headlight Switch (Read 1327 times)
Mrclubike
Re: Euro Headlight Switch
Reply #15 - 02/11/18 at 17:34:39
Most people feel the LEDS do as good or better  on low beam as the standard bulb
But My opinion is they are a little weaker than the normal on high
I also have Aux Floods on with the high beam to fill in where they leave off
Mrclubike
Reply #16 - 02/11/18 at 17:42:30
Tony Smith wrote on 02/11/18 at 17:27:07:
skippyc wrote on 02/11/18 at 16:55:52:
I replaced my headlight with a 20w led bulb and i was surprised how much light it throws out.
https://www.aliexpress.com/item/Motorcycle-LED-Headlight-High-Low-20W-2500LM-HS1...
How did you fit that?
Wouldn't this one better fit the standard headlamp? Or have you changed your headlamp assembly?
https://www.aliexpress.com/item/Plug-and-play-led-motorcycle-headlight-H4-HS1-hi...
I think this may be better 20w instead of 8
https://www.aliexpress.com/item/Motorcycle-LED-Headlight-H4-Hi-Lo-20W-2500LM-HS1...
Mrclubike
Reply #17 - 02/11/18 at 17:47:00
When installing these you  will  have to remove the bulb shield inside the headlight
Just a warning you may need to replace the gasket because it may tare when separating the glass from the reflector
Tony Smith
Graduate, Wallace and
Gromit School of Engineering
Reply #18 - 02/12/18 at 00:44:13
Mrclubike wrote on 02/11/18 at 17:47:00:
The penny finally dropped.
In Australia the R65 didn't get the "3 piece suit" headlight with separately replaceable glass lens, reflector and bulb.
What we got was an incredibly rare (last eBay quoted price in the vicinity of $150) semi sealed beam that is supposedly 7" but really isn't as the lens has a reduced diameter so as to provide a "landing shelf" so that it sits inside the chrome bezel and is then secured with a number of "L" - springs. The bulb is a fairly standard H4 type.
I have suspected for some time that R65s in other jurisdictions got different headlights and Mrclubbike's post sort of confirms it.
skippyc
Senior Member
Shouldn't have sold them
old bikes.
Reply #19 - 02/12/18 at 06:41:00
To answer the fit, it just went straight in. I paid $15 for mine so it is probably the one you put up, that is no longer available. I just looked at the site and picked the globe that looked the same.
Matt Chapter
<insert witty remark here>
Reply #20 - 02/12/18 at 14:42:38
BPT wrote on 02/08/18 at 12:27:40:
As far as the comparison between our models, I still wonder why Max wouldn't show it for mine if it was a straight up fit.
I sorta missed this when replying the first time - the reason the parts fiche doesn't show the euro headlight switch assembly for a US bike is, of course, that the euro switch doesn't fit the legalities here in the US.
Motorcycles in the US have been required since the 70s to have an "always on" headlight, so there's no reason to sell a switch that could circumvent that law.
skippyc
Senior Member
old bikes.
Reply #21 - 02/12/18 at 16:33:52
My mate told me my Led globe was not ADR approved.
(ADR Australian design rule)
Tony Smith
Reply #22 - 02/12/18 at 17:00:26
skippyc wrote on 02/12/18 at 16:33:52:
I say MEH! to the ADRs. (The GSA has LED low beam, HID high beam, 2*1,500 lumen LED running lights, a HID flood light on the left of the beak and a HID pencil spot on the right [trucks dip their light for me a long way away]
The running lights are angled down so that the "puddle" of light they emit does not extend more than 20m in frotn of the bike, the HID flood is angled slightly lieft and usefully illuminates a 50m swathe of road verge out to about 100m, the high beam is angled so that the horizontal cut is about 150m ahead of the bike, the pencil spot at 500m. The LED low beam sort of lets cars know I'm there during the day - it is useless at night, but then so where the OEM bulbs - R1150 GS & GSAs are generally regarded as having the most crap stock lights fitted to a motorcycle in the past 30 years (my 1984 XT350 headllght is better, even with the stock 50/55 watt bulb).
As a nod to the ADRs I am about to change the HIDs on the beak to 35w LEDs  as the HIDs are absurdly bright and throw light further than I need and therefore needlessly annoys other road users. I might put the HID flood on the R100.
wilcom
Reply #23 - 02/12/18 at 18:48:30
Tony Smith wrote on 02/12/18 at 00:44:13:
I have "L" springs on my US model....... I know because when I took my headlight out to change bulbs two "L" springs went flying across the garage. I never found one of them so I am running an incomplete motorcycle Roll Eyes
1979  R65
1980  R65
1972  R75
1964 R50
BPT
Reply #24 - 02/12/18 at 20:59:25
Matt Chapter wrote on 02/12/18 at 14:42:38:
Hey Matt - I think you misunderstood my post about that, or I didn't word it correctly.  Max shows both switches for the later models but only the non-Euro for my earlier one.  I thought about the legal aspect when I was only looking at mine.  But when I saw that they also listed the Euro version for the ones a couple of years later, that's what made me think there might be a difference.
BPT
Reply #25 - 02/15/18 at 15:23:37
Hey MrClubike - regarding LED, I have changed everything to LED except for the instrument panel and the headlight.
There have been a few threads here I've asked questions on about the headlights. I know that there are a few guys here that have changed and are happy.  For a while I think it was difficult to get the reliability/good beam/price all in one good package.  And the last time I looked it appeared to be $40 and up is what would get you something decent.
I have too many other things right now to deal with but would eventually like to switch the headlight to LED.
YaBB Administrator
I love my Beemers
Reply #26 - 02/15/18 at 20:28:23
I bought a new 1978 R100/7 and it had the same switch as the "Euro" bikes.
WWW
BPT
Reply #27 - 02/15/18 at 22:14:24
Did you notice any differences, Justin?  I mean as far as what they're talking about with certain things not working when it's in certain positions?
To be honest, I doubt I'd notice the difference. I'm not even sure if I have a "parking" light.
My current switch is bad so I needed to replace it anyway. I thought the Euro style would be good since it gave the option to turn the headlight off.  But I didn't know it would change so many other things.
I guess as long as all the necessary lights work when it's in the full on position, that'll be fine with me.  But it would be nice to have it work correctly, if possible, and also to know what to expect.
YaBB Administrator
I love my Beemers
Reply #28 - 02/16/18 at 15:54:43
I think the only difference was the ability to turn the lights off.  It's been so long ago that I can't remember if it also turned off the tail light but I would bet it did.  I think when one of these is put on a "big bike" there is a slight wiring change but not sure about the R65.
WWW
jp9094
Junior Member
Reply #29 - 02/16/18 at 16:51:50
Hi All,
Thought i'd jump in here. My 1983 r65 LS has the multi position "Euro" switch and it was purchased new in the US.  On the advice of Barry, "Senior Member" I replaced my park light with a 20 Watter. from Moto Bins. I find it bright enough to fool the boys in blue into thinking I have my headlights on and saves the alternator output for charging my battery! Of course I have to remember to turn the switch to the appropriate position when I ride. Also I found a site selling a replacement 3 position US switch for these bikes. Of course I cannot remember which one it was (oh the cruelty of old age!). Will have a look and get back to you all.
Best regards from Brooklyn.
