Normal Topic Driveshaft lubrication (Read 228 times)
Runninn1
YaBB Newbies
02/12/18 at 07:52:21
The splined driveshaft fits over the geared rearend drive & is immersed in 150cc of gear lube. The question is why? (Don't shoot the messenger). Wouldn't keeping the shaft lubed (agreeable difficult due to location) be sufficient. Is heat the issue and the gearlube therefore required? If it were easier to access and had a zerk fitting, would this be sufficient?  Thanks
Barry
Re: Driveshaft lubrication
Reply #1 - 02/12/18 at 12:11:49
There's also the joint at the other end of the shaft to consider and that needs some splash lube.
Runninn1
YaBB Newbies
Reply #2 - 02/12/18 at 13:32:12
Put a zerk fitting on that one too. Just being difficult.... Smiley
Tony Smith
Graduate, Wallace and
Gromit School of Engineering
Reply #3 - 02/12/18 at 15:25:58
Runninn1 wrote on 02/12/18 at 07:52:21:
I've wondered about this myself. Some years ago I had the universal joint on my R100 replaced with a Honda item (which is both fitted with a grease nipple and well sealed) due to the failure of the original and the fact that BMW do not recognize this as a repairable item and want you to buy a new shaft. Anyway, I was smart enough to slather grease into the spline coupling, but I didn't actually put any oil in the housing because I simply didn't realize that oil was supposed to go there (young didn't read manuals closely).
Exactly nothing bad happened.....
Some years later I went to a BMW club tech day and discovered there was supposed to be oil in there, so I put some in.
My wife's R65/80 has had a failed seal in the nose of the final drive for donkey's years - it is pointless putting oil in the shaft because it just migrates into the final drive and leaks out (assuming the final drive was filled to the original factory recommendation and not the later one.
The OEM universal joint from 1979 has yet to fail so I have my doubts that it needs splash lubrication, I harbour even greater doubts that it is even capable of being splash lubricated.
Yamaha, who largely copied the BMW shaft drive for the XS 750/850/1100 models ran the driveshaft dry, but used a very sticky Molly grease on the coupling.
Para-lever shaft housings with two universal joints are run dry.
I *think* that with lots of grease in the splined coupling  that there is no reason the shaft cannot run "dry". I also think that the work involved in tipping 100ml (my "bet each way") of oil into the housing is neither here nor there.
Mrclubike
Reply #4 - 02/12/18 at 20:09:50
That is a very good question
I may have to look into this because for some stupid reason the oil in my drive shaft some how pumps into the transmission thru the vent slot
I figured after I resealed the trans it would stop doing this but it didn't
Runninn1
YaBB Newbies
Reply #5 - 02/13/18 at 14:56:45
I check mine annually and it's often almost empty  Huh.
Yet the splined shaft and gear appear factory fresh after 70k miles. I do keep it well greased.
