Hot Topic (More than 10 Replies) LED Tail / Brake Light (Read 548 times)
Bob_Roller
Global Moderator
  GMT -7 Hours
04/14/18 at 10:49:01
I just replaced the two tail light / brake light bulbs, dual filament 1157 bulbs on my Guzzi .
I've got a voltmeter in the instrument cluster and when I apply the brakes, I would see about a 3 volt drop on the voltmeter .
Now with the LED's installed, no meter movement upon applying the brakes .
Each filament of the incandescent bulbs, is 21 watts, so with the tail light on and the brake applied, it's around 84 watts, a bit under a third of the charging system output at high rpm's .
The Guzzi has the same Bosch charging system as the airheads .
Tony Smith
Graduate, Wallace and
Gromit School of Engineering
Re: LED Tail / Brake Light
Reply #1 - 04/14/18 at 16:10:00
Yep.
Long ago replaced the tail light and brake light on my R65 with LEDs.
I fitted two of the same output but it works out OK as the internal reflectors and lenses in the R65 tail light housing make the brake light more "focused" and therefore it appears brighter that the tail light. I couldn't think of any downside to having a brighter than standard tail light.
Mrclubike
Reply #2 - 04/14/18 at 21:48:54
Tony Smith wrote on 04/14/18 at 16:10:00:
Yep.
I have done the same
The LED brake light bulb is a lot brighter than stock incandescent bulb
More brighter = more safer  Grin
Change out the headlight also and you will rarely see the volt meter go into a discharge voltage (below 12.5 at 1100 rpm)
Will at least   with the Delco "A" circuit voltage regulator
Not sure with the stock type "B" circuit
Either way it frees up a lot of charging capacity  Smiley
Mrclubike
Reply #3 - 04/14/18 at 22:00:19
The ZEVO LED's work great
Get reds for the brake and tail and amber's for the turns
They have to be trimmed up to fit in the sockets and the tip of the heat sink has to be cut off to fit under the  tail  light lens
Don't waist you money on the Emerald island LED tail light conversions
The ZEVO's are brighter
Bob_Roller
Global Moderator
  GMT -7 Hours
Reply #4 - 04/15/18 at 13:31:18
On my R65's I put an aftermarket tail light / brake light part from Motorrad Elektrik, Beacon 2 .
I got them about 14 years ago, before LED bulbs were available .
http://www.motoelekt.com/lighting.htm
I put Sylvania ' tower ' type LED's on the Guzzi, I think they have about 18 LED's on each bulb .
https://www.carid.com/sylvania/led-bulbs.html?relationshipId=1264494980&childId=...
If anyone decides to convert to LED's, remember to match the color of the LED, to the color of the lens it shines through .
Mrclubike
Reply #5 - 04/15/18 at 16:33:19
I have seen the Zevo along side the Motorrad Electric / Emerald Island
I  promise  you the Zevo's are brighter  and cheaper
  If you look at  the Zevo
The led points back to the reflector not out
This gives you a very bright light
qwerty123
Junior Member
Reply #6 - 04/18/18 at 18:45:09
I can corroborate, good 1156 LED units, like Zevo or from superbrightLEDs.com, are brighter than the Emerald Isle / Motorrad Elektrik Beacon lights.
BPT
Reply #7 - 04/19/18 at 13:42:06
Do you trim the white plastic "shoulder" part to make them fit into the socket?
It looks like that is what is keeping the bulb from seating on mine but it's also where the seam on the plastic housing is.  Maybe it just  needs a small amount taken off to make it fit?
Bob_Roller
Global Moderator
  GMT -7 Hours
Reply #8 - 04/19/18 at 17:50:04
How many LED's do these Zevo bulbs have ??
Where did you purchase them ??
I was thinking of changing out the 1157 bulb on my oilhead for an LED replacement .
Mrclubike
Reply #9 - 04/19/18 at 19:32:20
BPT wrote on 04/19/18 at 13:42:06:
Yes
Mrclubike
Reply #10 - 04/19/18 at 19:33:24
Bob_Roller wrote on 04/19/18 at 17:50:04:
Just 2
But they are focused back to the reflector
BPT
Reply #11 - 04/19/18 at 20:30:14
Thanks MrClubike.  I thought that was the only place to do it but wanted to make sure that it wouldn't come apart since there is that seam and tabs there.
I'll try a little at a time.........
davidpdx
Full Member
Reply #12 - 04/20/18 at 23:50:00
I don't know if it is legal everywhere but I installed a flashing LED brake light on all my bikes. Super Bright LED has them and it is one of the best safety items I have added to my bike. Lots of car drivers just are not paying attention and a little strobe can wake them up sometimes.
1984 R65 60K+
1946 Triumph Speed Twin
Being shot out of a cannon will always be better than being squeezed out of a tube.  That is why God made fast motorcycles, Bubba…
— Hunter S. Thomps
