Normal Topic Neutral => RPM:1000, 1st gear => RPM:650 or stop.. (Read 312 times)
guyom
Junior Member
05/08/18 at 08:29:36
hi Guys, since one week got a "new" situation on my bike (R65-1981) :
when the bike is in neutral, everything fine, normal RPM. but since i put the 1st gear.. RPM drops... to low (650) and half of the time the motor stops (except with a bit of gaz.. which is not practical...).
When i downshift... if i miss the neutral.... and stop in 1st Gear.. neutral is really difficult to find.. the bike also want to run and i have to maintain it... so well any ideas ? does it come from the carbs... and some kind of air flow or i do not know what, comes from the clutch... and what to do or come from the gear box... (and to be honest... the first is closed to be dead Wink but works again.
Thanks for time
Guillaume
georgesgiralt
Re: Neutral => RPM:1000, 1st gear => RPM:650 or stop..
Reply #1 - 05/08/18 at 11:25:55
Hello,
Looks like your clutch is grabbing.
Why ? That's the question ...
Maybe the lever and cable play are not set up properly or the disk has gotten oil on it making it stick or the clutch spring is worn, or .... or ...
I for one would adjust the cable play and see what comes out of it.
Then will report back.
guyom
Junior Member
Reply #2 - 05/08/18 at 12:07:03
thanks for answer. i will try the cable !
Barry
Reply #3 - 05/08/18 at 13:06:31
I agree with Georges. Both the rev drop and the difficulty in finding neutral point to the clutch dragging.
guyom
Junior Member
Reply #4 - 05/08/18 at 13:49:21
any suggestions or adjustment ? i worked on the cable this afternoon no road test yet Smiley
Barry
Reply #5 - 05/08/18 at 15:00:18
Regardless that it doesn't seem intuitive, do it exactly as described in the handbook:  Use the knurled adjuster at the handlebar end of the clutch cable to set 201 mm of exposed inner cable at the gearbox end, then use the adjuster on the gearbox end clutch actuating lever to set 2 mm of free play at the handlebar lever.
Tony Smith
Graduate, Wallace and
Gromit School of Engineering
Reply #6 - 05/08/18 at 16:01:40
guyom wrote on 05/08/18 at 08:29:36:
Could you do something for me please? With the engine stopped, put the bike into 1st gear. Now pull in the clutch and hold it, now push the bike. Is it hard to push?
guyom
Junior Member
Reply #7 - 05/09/18 at 10:42:12
i will try that this weekend  and report ! thanks for advises !
