Normal Topic LED Head light and & 7 inch bucket (Read 316 times)
Mrclubike
05/10/18 at 22:38:24
I was running a Adventure monster LED head light bulb in the OEM head light assembly to save wattage
It work well but failed after 14 months or about 11000 miles
I also had problems with condensation on the inside of the head lamp
So instead of going the replacement bulb route again I decided to fit a purpose built head light assembly
I found a 7inch Speaker 8700 EVO 2 (not dual burn) for $200 shipped on eBay
But the 7 inch does not fit the OEM bucket
I found the Lucas 7 inch reproduction buckets on eBay for $33 shipped
Believe it or not the new bucket fit fine
I Only need to ad some spacers to the side to match the width and get  two  5/16 24 bolts
Of course the charging system works great with all of the LED's fitted with no discharge at 1100 rpm
« Last Edit: 05/19/18 at 14:52:01 by Mrclubike »
Mrclubike
Re: LED Head light and & inch bucket
Reply #1 - 05/10/18 at 22:44:17
You think $200 is high look at the cost of  a new Bosch unit
The Speaker 8700 is a top of the line LED head light
Mrclubike
Re: LED Head light and & 7 inch bucket
Reply #2 - 05/20/18 at 10:41:02
I ended up JB (epoxy) welding the spacer to the sides of the bucket
two 3mm spacers on each side for a total of 12mm
To epoxy these on just make sure you put a coating of grease on the bolt before you screw it all together
Then after it sets up remove the bolt and clean the grease off and reassemble
Mrclubike
Reply #3 - 05/20/18 at 10:41:38
Another very good LED head light is the Truck lite
I really like the looks of this light better
It is a dual burn type
When on High beam both the High and Low  are on together
This conversion could be done for less than $200 USD
In the EU you can get this light with the parking bulb
Mrclubike
Reply #4 - 05/20/18 at 10:54:53
Here Is the EU version
YaBB Administrator
I love my Beemers
Reply #5 - 05/20/18 at 12:17:09
Interesting.  I've not tried LED headlights but did convert to HID on the Junkyard Dawg and my '95 R100RT.  I have been thinking about HID on my '81 R100RT but maybe I'll rethink an LED solution.
WWW
georgesgiralt
Reply #6 - 05/21/18 at 02:17:01
There is a discussion on ADVrider about Evitek H4 LEDs and why they are very good.
I would prefer an H4 equivalent in order to conceal the lighting modification... Just in case the LEO search for something...
