Hot Topic (More than 10 Replies) Bar replacement (Read 755 times)
roadkill
YaBB Newbies
Bar replacement
05/25/18 at 18:50:44
Trying to put my 82 r65 back to mostly stock configuration after a previous owner had "improved" it.  PO changed the bars to a short low bar that won't allow the dash pad to fit properly.  Where would I find an aftermarket bar that is most like the OEM. Or, if someone has a nice original, I might be interested.
Also need the bulb assemblies for turn signals. When he threw away the original dash pad, he chucked the in-dash signal lamps as well.  What might be a good source for those?
wilcom
Online
Re: Bar replacement
Reply #1 - 05/25/18 at 20:30:52
Roadkill.........
Take some pictures of your bike so we will have a visual and will be better able to guide you. Next, go to WWW.realoem.com and look up your bike and find the part numbers of the stock pieces you are needing.  Pictures first, let us "see" what you need.
1979† R65† †
1980† R65† †† †† ††
1982 R80RT†
1974 R90/6††† †
1972† R75† †† †††
1964 R50
Mrclubike
Re: Bar replacement
Reply #2 - 05/25/18 at 21:44:53
roadkill wrote on 05/25/18 at 18:50:44:
Trying to put my 82 r65 back to mostly stock configuration after a previous owner had "improved" it.† PO changed the bars to a short low bar that won't allow the dash pad to fit properly.† Where would I find an aftermarket bar that is most like the OEM. Or, if someone has a nice original, I might be interested.
Also need the bulb assemblies for turn signals. When he threw away the original dash pad, he chucked the in-dash signal lamps as well.† What might be a good source for those?
Motobins
and
Motoworks
https://www.motorworks.co.uk/vlive/Shop/Parts.php?T=5&NU=15&M=20&Ct=OA&SbCt=BA_1...
Industrial mobile equipment Mechanic †for over†35years †
Mrclubike
Re: Bar replacement
Reply #3 - 05/25/18 at 22:09:16
I put RT bars on mine and I had to drill a hole in the dash pad to prevent the clutch cable from kinking
They are taller than the original bars
Mrclubike
Re: Bar replacement
Reply #4 - 05/25/18 at 22:13:59
Are you looking for these
Moto Works and Motobins has them
roadkill
YaBB Newbies
Re: Bar replacement
Reply #5 - 05/26/18 at 07:50:54
Mrclubike wrote on 05/25/18 at 22:13:59:
Looking for the lamps (bulbs) and the sockets with wire. My lenses are ok.
roadkill
YaBB Newbies
Re: Bar replacement
Reply #6 - 05/26/18 at 07:58:07
Pics of what going on.  Bars are not as wide as OEM, pic 1 and 2 show what I have.  Pic 3 is what I'm looking for.  (Hope the pics show up) Embarrassed
wilcom
Online
Re: Bar replacement
Reply #7 - 05/26/18 at 10:11:54
Thanks for the pics Roadkill. Check to see if there is a part number on the short bars to give us an idea what they were for(maybe your bike?)
When I fitted my short bars I put on the dash pad and left the bars and controls lose and adjusted with the tilt of the bars and the tilt of the controls since the dash pad is immobile and everything else will move.
I'm sure there are folks on the East Coast but I use Stoners Beemer Stash here on the West Coast for odds and ends. I just got the original bars for my LS from him along with a couple of other onesy twosy items.
Stoner's Beemer Stash
Larry Stonestreet      39628 Avenida Miguel Oeste
Murrieta, CA 92563
(951) 813-1704
ca.stoner@yahoo.com
1979† R65† †
1980† R65† †† †† ††
1982 R80RT†
1974 R90/6††† †
1972† R75† †† †††
1964 R50
Mrclubike
Re: Bar replacement
Reply #8 - 05/26/18 at 11:09:15
I have gotten Part from this guy on eBay
You can send a message to him and see if he has them
https://www.ebay.com/usr/reclaimbmws?_trksid=p2060353.m2749.l2754
georgesgiralt
Re: Bar replacement
Reply #9 - 05/26/18 at 13:00:21
If I'm not mistaken, the bulb holders are still available new from BMW and surely from the Brits.
The bulbs are 3 to 5 W T bulbs as used on cars.
But the bulb holders have flat spades for AMP style spade on the wires... So you may have to "rewire" a bit...
The OEM wiring loom is still available new from BMW. Last time I looked it was around 160 Ä plus shipping.... So ....
For the bars, I would ask a place like Motorworks for a decent used one.
jp9094
Junior Member
Re: Bar replacement
Reply #10 - 05/26/18 at 15:43:17
I'm afraid, the bulb holders are no longer available s I tried to source them a while back. They hold 12 volt 194/BP2 bulbs. They have bendable wire loops that make the contact with the bulb holders. Problem with mine were they were stretched and when I tried to tighten them, the broke (or at least 2 diametrically opposed contacts did). I solved the problem by bending one loop over to the other side so they made the appropriate contact. By the way, if you find a source for them, please let us know!
Thanks in advance.
georgesgiralt
Re: Bar replacement
Reply #11 - 05/26/18 at 16:10:49
Well, Motorworks has them, new :
Instrument bulb holder | INA81725
roadkill
YaBB Newbies
Re: Bar replacement
Reply #12 - 05/26/18 at 16:50:08
Thanks for the replys.  I've contacted a few vendors. I'll post on this forum asking if anyone has a decent set of stock bars.
roadkill
YaBB Newbies
Re: Bar replacement
Reply #13 - 05/26/18 at 19:17:45
georgesgiralt wrote on 05/26/18 at 16:10:49:
It seems INR 44626 is listed for 80 to 85 R65.  No longer available from BMW, but they may have some.  "Stock of this item varies, check for availability and condition".  These is a used item.
donbmw
Senior Member
Re: Bar replacement
Reply #14 - 05/26/18 at 19:52:25
I have a Don Vesco Rapid Transit fairing on my 82R65. I put the sport bars on that came with the fairing I had the same amount of rise as your picture shows and hand no problem installing the dash. Looking at your picture the bar clamps need to be loosened and rotated back. I now have RS bars installed still with the stock dash installed
Don
WWW
roadkill
YaBB Newbies
Re: Bar replacement
Reply #15 - 05/28/18 at 05:27:47
donbmw wrote on 05/26/18 at 19:52:25:
I fiddled with the bar position, and also moved the hand controls further outboard.  I did get the pad to fit.  Now, the only issue is that it had bar end mirrors, which won't work, since I've move the hand controls out.  So, I'll try to come up with a set of mirrors, and see how things work.  We're getting there. Smiley
Don
donbmw
Senior Member
Re: Bar replacement
Reply #16 - 05/28/18 at 09:02:19
I donít see how the bar end mirrors canít be used because of controls. I have seen them used all type of low bars to even clip ones.
Don
WWW
roadkill
YaBB Newbies
Re: Bar replacement
Reply #17 - 05/30/18 at 06:51:23
donbmw wrote on 05/28/18 at 09:02:19:
Don
The flat bars are not very wide, and in order to get the dash pad to fit, the grips and controls had to be slid outward about an inch and a half on each side.  Consequently, the is no "handle bar" under the outer portion of the grips.  The bar end mirrors won't anchor without the handle bar, ie. they won't attach to just the grips.
Barry
Re: Bar replacement
Reply #18 - 05/30/18 at 08:11:35
Those flat bars are the wrong shape rather than being too narrow.  The stock BMW euro bars are narrow but straighter. The pad fits fine although I need to loosen the right hand controls to rotate then up a little to fit the pad and then rotate them down again.  It's worth going to some trouble to make the pad fitting easier as  forcing causes them to split. An intact pad with no splits is going to become a rare and expensive item in the future.
