Page Index Toggle Pages: 1 [2]  Send TopicPrint
Hot Topic (More than 10 Replies) R65 - strangled engine when warm (Read 704 times)
Bob_Roller
Global Moderator
  GMT -7 Hours
Re: R65 - strangled engine when warm
Reply #15 - 06/29/18 at 17:26:24
Alright, you knew where I was going with this !!! Grin
baffle
YaBB Newbies
Reply #16 - 06/30/18 at 10:36:38
Sorted now. Two things. My fuel filter was a bit clogged (with bits of red paint which are a mystery to me as to where they have come from) so that's clean now, and I've also replaced my fuel lines.
I'd replaced my fuel lines this time last year, when I started to get the old petroly boot (which I assumed to be float bowl gasket but was in fact split pipe on nozzle). I was perhaps too generous with the line between T piece and LH carb, and that piece of pipe had a curve in it which in the unusual heat in the UK had caused the pipe to kink and restrict the flow. This tallies with the plugs which both looked a bit too lean for my liking, but they are nice and biscuity now.
thanks for help everyone.
Lurking with my R65 1980 since 2008.
Mrclubike
Reply #17 - 06/30/18 at 20:03:23
The red paint is the petrol tank liner coming loose
Mine has been shedding off  for that last 4 years
But I have never had an issue with it clogging any thing yet
I do use a clear inline fuel filter
DadsR65
YaBB Newbies
Reply #18 - 07/09/18 at 19:56:36
I learned the hard way:  when you think it's a fueling problem, it's probably ignition (and  vice-versa).
I chased a main jet problem for a month that turned out to be a points issue.
