Hello
Here's a quick update for anyone who has been following/helping my project....
My right hand spark fouling up turned out to be a blocked slow air jet on the carburetor - cleared and all running much smoother now!!
(also successfully moved onto French plates.....which hasn't boosted my performance....)
So generally pretty good, and next job is to replace my leaking fork seals for which I would appreciate some help.
I'm hoping to follow a video tutorial (for a R100CS fork seal replacement) see link
https://www.youtube.com/watch?v=s9AfQOrwEeYwhich doesn't take the whole forks apart, just the following;
1/ front wheel off
2/ release dampener rod allen screw lower leg fastener
3/ slip off the fork lower leg
4/ pop out the old seal and replace
5/ put back together and refill with oil
does sound sound about right?
I have some Multi ATF which is described as equivalent to DEXRON III H. Should that be ok for the fork oil?
My haynes manuel says 190cc for each fork and also 30 - 40 Nm to torque up the dampener rod allen screw...?
Any hints appreciated
