Page Index Toggle Pages: 1 ... 3 4 [5] 6 7 ... 16 Send TopicPrint
Very Hot Topic (More than 25 Replies) R65 Resurrection (Read 18878 times)
skippyc
Senior Member
Shouldn't have sold them
old bikes.
Re: R65 Resurrection
Reply #60 - 11/17/18 at 15:30:49
Copper washers are good they seal with less torque.
I found no use for the smaller oring either.
Mrclubike
Ex Member
Reply #61 - 11/17/18 at 19:04:33
Aethelric wrote on 11/17/18 at 04:54:32:
I'll be interested too. I could not find a place for the big metal "shim" either. Nothing like that came out of the old one.
Just because you didn't remove a part when you dissembled it doesn't mean you don't need it
Previous owners are notorious for screwing things up   Angry
The large diameter shim in the kit is critical in some applications
If your engine requires it and you leave it out you can have loss of oil pressure and destroy your engine
I do not know the cut off dates of when it is and isn't required
But a simple search of the "2000 dollar O ring" will tell you all about it
But the best info is here at Snowbums tech articles
http://bmwmotorcycletech.info/technical-articles-list.htm
After you are there scroll down to the Mechanical section and then to Line 51a
Every Airhead owner should be aware of the issue with properly installing an oil filter
Bob_Roller
Global Moderator
GMT -7 Hours
Reply #62 - 11/17/18 at 20:52:55
Looking at the o-ring assortment, I think the smaller black o-ring, may be for the oil dipstick .
Aethelric
YaBB Newbies
Reply #63 - 11/18/18 at 07:44:02
Thanks for that mrclubbike. Checking on Antons site it seems I need the shim, but not the gasket.(Canister depth is 3.5mm) When I dismatled it there was a gasket but no shim.
The old O ring (black not white in my case) had obviously been installed with some sort of sealant. So it is now reassembled with no gasket, and one shim, torqued up to hand tight with a T spanner and loctited (I don't believe in lock washers.
The black 30mm O ring fits the filler plug and the 20mm copper crush washer fits the drain plug.
Bob_Roller
Global Moderator
GMT -7 Hours
Reply #64 - 11/18/18 at 13:06:10
None of the fill or drain plugs use a rubber o-ring, they all use metal washers .
Mrclubike
Ex Member
Reply #65 - 11/18/18 at 23:33:53
some Dip sticks use the Oring
Mrclubike
Ex Member
Reply #66 - 11/18/18 at 23:35:52
Aethelric wrote on 11/18/18 at 07:44:02:
Very glad you Fixed it  Grin
TomHoldom
Full Member
Reply #67 - 12/01/18 at 04:17:37
Hello Again -
my new SLA battery has arrived and I want to check whether I will be ok using my 12 V car basic car battery charger (bought from halfords around 10 years ago).
Read about risk of damage if over charged
Thanks
Barry
Reply #68 - 12/01/18 at 04:32:14
The only thing thing to worry about on a sealed battery is continuing excessively high charge voltage once the battery has reached full charge.
A wet cell battery will gas once fully charged but a sealed battery will eventually vent on the pressure relief valve which will shorten it's life.
So you can use any charger on an SLA battery provided you monitor charge voltage and don't allow it to exceed the manufacturers recommendation. In the absence of a manufacturers figure 14.5 volts would be safe.  And then when it reaches full charge take it off.
Conversely leaving an SLA on an unregulated charger which might easily reach 16 volts or more once the battery reached full charge would be the kiss of death.
TomHoldom
Full Member
Reply #69 - 12/01/18 at 06:51:50
ok thanks Barry
I wont leave too long.
Any idea how long a first charge might take, and can I rely on the 'ready' indicator light as a safe voltage check, or would I be better off using a voltmeter?
Barry
Reply #70 - 12/01/18 at 09:14:30
If the charger has a ready light then it's not an old unregulated type so it should be safe.   It's right to charge a new battery before putting it into service but it shouldn't need much at all.
TomHoldom
Full Member
Reply #71 - 01/10/19 at 11:31:21
I'm about to order my tyres from my 1978 R65 and wondering whether I need to be concerned about not have a 'matching' pair
I don't want to spend too much and at the moment I'm hesitating between:
Front tyre: Metzeler ME22 90/90 - 18 (57P) (29)
Front tyre: Metzeler ME22 - 3.25-18 59P. (39)
Rear tyre: Metzeler LASERTEC 110/90 - 18 (61H) TL (88)
Rear tyre: Metzeler PERFECT ME77 4.00R18 64 H (89)
any advice appreciated
(existing old tyres are,  front: 90/90 - 18.51 H & rear: 120/90 H18)
Thanks
Tom
Tony Smith
Graduate, Wallace and
Gromit School of Engineering
Reply #72 - 01/10/19 at 14:50:39
TomHoldom wrote on 01/10/19 at 11:31:21:
rear: 120/90 H18)
You may well fid that to fit a 120/90 that a modified spacer kit has been fitted to the rear wheel to move it to the left somewhat. Nothing wrong with that except that if the drive splines in the hib and wheel have taken a "set" it isn't really reversible.
1978 R100RS| 1984 R65 | 1992 KLE500 | 2002 R1150GSA | 2019 DRZ 400
TomHoldom
Full Member
Reply #73 - 01/17/19 at 01:46:01
ok thanks Tony, I'll have a look for that - if I upload a photo of the rear wheel would you be able to tell whether a spacer has been fitted?
Is the issue of having a matching pair important - the website I was looking to buy the tyres said I have to have a matching pair?
Tony Smith
Reply #74 - 01/17/19 at 06:02:50
You will need to measure the spacer to see if it is longer than standard - not a difficult task.
Tyres that are meant to be used as a pair should be used as such. The problem is sorting out tyres that are genuine pairs from those that are marketing hype.
Some 120/90s will fit, some will not. Unfortunately with the steady disappearance of "inch" tyres and the ever bigger tyres being fitted to new bikes the 110/90 which is a pretty much guaranteed fit has all but disappeared, other than for really ghastly tyres like Shinko.
