Very Hot Topic (More than 25 Replies) R65 Resurrection (Read 2774 times)
TomHoldom
YaBB Newbies
R65 Resurrection
09/24/18 at 11:39:06
OK here goes; I'm pretty much a novice so please excuse my ignorance.
I have a 1978 R65 which I bought around 20 years ago, used on and off for 10 years, then left for 10 years (undercover) and now am getting going again.
Battery obviously dead, but a friend hooked it up to their car and managed to get the engine to splutter back to life.
So I'm looking for advice on my next moves...
Oil change:
Before I do much else I was planning to change the oils
engine / gearbox / driveshaft / rear bevel ?
Currently with no battery not so easy to get the oil warm, can I do this with a cold engine?
Any advice on which oils?
Planning to buy the motobins oil filter exchange kit (code 01955A) which includes a new filter
b.t.w I had ear-marked the Power King PK-12180 12V 18Ah Sealed Lead Acid Battery (€46 in France) which fits in my enclosure - sound alright?
Front Disk brake:
Before I stopping using the bike there was a small leak in the front brake master cylinder. (which has now ruined the paintwork on my front mudguard)
At the moment I’m still stuck with trying to get the reservoir cap off (round type) as 2 of the 3 screws are turning without coming out, but assuming a can remove this, I was going to buy the £40 Motobins “Brake master cylinder overhaul kit (16mm)”, but wondered whether there is anyway of knowing whether this will solve my problem.
At the moment I’m trying to avoid changing to the later square reservoir as I understand I’ll need to change the whole throttle assembly
Fuel supply:
When I disconnect the pipe from the bottom of the fuel tap and turn on the tap, there is only a rapid drip which feels like its not rapid enough and might need clearing. Is there any way simply check my flow rate to check whether I need to disassemble and clean the tap - or is that obviously blocked?
Also on my first motobins order planning to include Carburettor rebuild kit (code: 60020A), and new air filter (code: 03200)
Obviously this just phase one to get the thing rolling again, and I would appreciate any help and advice on the above, and all the obvious stuff I’ve missed….
Thanks
« Last Edit: 09/25/18 at 22:44:22 by Justin B. »
Barry
Re: Leaking Master Cylinder
Reply #1 - 09/24/18 at 14:38:14
If all the oils were changed just before putting the bike into storage I would run the bike to get everything hot before changing them.  New oil doesn't deteriorate that much in storage, particular the transmission oils which don't have the source of contamination that the engine does.
If the oils weren't fresh then change the engine oil without doubt  before running the engine even if that means a cold oil change.  If the oil comes out looking terrible then you might want to drop the sump to clean out any settled sludge. In this case I wouldn't fuss about what oil to use as I'd be changing it again soon.
Battery sounds fine. Many of us are using cheap generic AGM batteries.
My round mater cylinder is all still original so I'm not sure what the Motobins kit includes. I doubt it includes the seal between the reservoir and metal body.
Fuel tap sounds obviously blocked possibly with stale fuel. I'd empty the tank to see what the state of the fuel is and what debris the tank contains. There should be a small mesh filter inside the bottom tap union which may be blocked. The tap can be dismantled, cleaned and rebuilt but it's a job that involves much swearing as you'll find out when trying to reassemble it.
Carbs will need a clean and rebuild with new O rings and diaphragm. Flat top Bings can have the diaphragm changed without replacing the whole slide assembly.  Other than the needle jet which is prone to wear there is no need to automatically replace any other jets if they clean up OK.  Floats probably will need replacement which you can check by weighing them. 12 - 14 grams is serviceable.
Round air filters last a very long so I wouldn't  automatically change it unless it's deteriorated or has a vast mileage on it.
Other things to look at ?  I'd be surprised if the Ate front brake caliper wasn't seized from corrosion.
TomHoldom
YaBB Newbies
Reply #2 - 09/25/18 at 08:23:55
Hi Barry thanks for all that.
I'll definitely change the oil then (hadn't done it for some time before I stopped using it)
Should I do them all, or could I just change the engine and simply check and top up levels on gearbox, drive shaft and rear bevel?
for the engine oil I read a 20w - 50 is ok?
for the gearbox 75W-90? & is this the same for the drive shaft and rear bevel?
The motorbins kit for the master cylinder only includes the piston assembly, but the diaphragm is apparently also still available on http://www.capitalcycle.com in the states. My problem is that I don't know what parts I need, as I don't know whats causing the fluid leak.....I guess once (if.....) I manage to get it apart this may become clearer?
For the carbs should I add needle jets to my order ? Or is there a way to look at them to see if they need replacing?
I'll check the floats.
I have the twin Brembo disks fitted to the bike, but I suppose your comment still applies to these. Would it be sensible to take these apart before refilling the system with break fluid? (see photo; there's a fair amount of rust..)
Lastly (for now at least) it looks like it would be sensible for me to add a torque wrench to my tool box, which one of the following would serve me best:
28 - 210 Nm, 1/2 inch or
7 - 105 Nm, 3/8 inch
Thanks again
Tom
TomHoldom
YaBB Newbies
Reply #3 - 09/25/18 at 10:13:39
Hi just taken the fuel tap from the tank and its full of rubbish - obviously needs a good clean out. Any advice on cleaning products would be useful
Barry
Reply #4 - 09/25/18 at 13:51:49
TomHoldom wrote on 09/25/18 at 08:23:55:
Changining the trasmission oils is less critical than the engine oil provided an inspection shows there is no water contamination but given you need only a little over 1 litre of oil it might be safer to change them. 75w90 is fine for all 3 and 20W50 for the engine.
Brembo calipers on a 78 are good news in many respects. It means they are not original and therfore not as old as the bike, they are less suceptble than Ate to corrosion and spares are much cheaper if you do need them.  Rust on the outside is not really a functional issue, it's whether or not the pistons have siezed. If they are not both free to move the brakes won't work and even too much stiction will cause the brakes to sqeal as the pistons will not retract. After 10 years I suspect you'll need to rebuild them.
Measuring needle jets for wear is a tricky business if you consider that the difference between one size of needle jet and the next size up is only 0.8 thousands of an inch. It therefore doesn't take much wear to make a big difference and you are not going to be able to measure that wear without accurate pin gauges which would cost more than new jets.
You can't do everything with one size of torque wrench but of the two the 3/8 wrench will be most useful.
The tap and therfore the tank are a mess and you will probably need to re-coat the tank inside. Not something I've done but you'll find lots of previous thtreads with a search.
YaBB Administrator
I love my Beemers
Reply #5 - 09/25/18 at 14:17:17
I have done three tanks and found the POR15 tank liner to be the best, IMHO.  The tank on my '81 R100 was very nasty inside, original liner flaking off, etc.  I used Muriatic acid and sloshed and rotated it for about 12 hours and the inside of the tank was a nice matte gray with no liner or rust left.  After rinsing and drying I coated with POR15 and today the tank is still silver on the inside - after about 13 years or so.
You might want to think about a new fuel tap.  They are about £28.00 + S&H from MotoBins.
WWW
Mrclubike
Reply #6 - 09/25/18 at 20:43:55
If you plan on rebuilding the calipers take them apart first to make sure what size the piston are
Hopefully they are the standard 38mm
Honestly I cant imagine riding the bike without rebuilding the brake hydraulics first
« Last Edit: 09/26/18 at 21:27:02 by Mrclubike »
georgesgiralt
Re: R65 Resurrection
Reply #7 - 09/26/18 at 02:09:11
And change transmission oil too. Brittany can be quite damp in winter, so I won't be surprised there is some water in the transmission. At first start you will mix the oil and water and turn it into some cafe looking junk.
I second the advice about braking. Planning to be able to stop the bike proper has to be done before putting gas in the tank.
Matt Chapter
<insert witty remark here>
Reply #8 - 09/26/18 at 09:37:47
TomHoldom wrote on 09/24/18 at 11:39:06:
I'd find an AGM battery instead, they last longer and require zero maintenance for about the same price.
TomHoldom
YaBB Newbies
Reply #9 - 09/26/18 at 09:39:13
Thank you Barry, Justin B, Mrclubike and georgesgirait for your advise.
All oils are draining as I type....one issue already which feels like it could be a big one, is that the drive shaft filler plug came undone nicely, but then just continued turning having only lifted a couple of mm...so currently can't get out for refill and presumably it may not seal up well? Any advice?
I'll try and take my Brembo Calipers apart this afternoon.
Can you tell from the photo above whether mine are the twin piston fixed type (they appear to be from the Haynes diagram)?
When I'm ordering parts is there a specific reference I can give to be sure to ordering compatible bits.
For example on the motobins site there is a caliper overhaul kit Code: 23300A    BMW: 34 21 1 237 234 which is for R65 1985 and onwards - could it be this?
Barry, I'll add a couple of needle jets to my motobins order for when I rebuild the carbs - just to be sure I've understood the part you're talking about is the attached photo right (obviously I'll check the size before ordering)
thanks Justin B. I'll order some POR15 and sort out the tank.
Thanks all again
Matt Chapter
Reply #10 - 09/26/18 at 09:59:40
TomHoldom wrote on 09/26/18 at 09:39:13:
You can tell by looking at the caliper that it's a single piston.  Since the '78 models came with ATE calipers, someone has done you a small favor and replaced the originals with Brembos.  Therefore, you can't go off of what the parts fiche says alone - you should measure the piston size and brake pads to determine exactly which caliper you have.  There are at least two different Brembo calipers used on the R65 from when the Brembos were introduced to '87.
Barry
Reply #11 - 09/26/18 at 11:33:01
Smart thinking Tom, in attempting to remove the filler plug before the drain plug. The various filler and drain plug threads strip easily if over tightened. They should not be more than 10 ftlbs and for filler plugs I use even less. It will need to be helicoiled.
Your calipers are twin piston in that there is a piston pressing on each brake pad as opposed to a single piston sliding caliper commonly fitted to cars.
The picture you posted does show the correct needle jets.
The work list is getting longer. I hope you don't find too many more issues.
YaBB Administrator
I love my Beemers
Reply #12 - 09/26/18 at 13:45:44
The small plug on the rear of the final drive is a sight plug.  It's best to leave this alone and remove the vent on top to pour in a pre-measured quantity of lube.
The "Junkyard Dawg" had this stripped as well so I drilled out the hole and made a threaded insert with M6 threaded hole, JB-Welded it into the hole, and used a SS screw with copper washer.  Worked like a champ!
On the POR15 kit, this is what I used along with the Muriatic Acid:
https://www.por15.com/POR-15-Motorcycle-Fuel-Tank-Repair-Kit-_p_106.html
WWW
Tony Smith
Graduate, Wallace and
Gromit School of Engineering
Reply #13 - 09/26/18 at 20:00:49
Ok, the horse has bolted on a sympathetic recomissioning of the engine, given that you have already started it and this picked up a fair quantity of whatever crud was sitting int eh bottom of the sump and run it through the pump, into the filter, and possibly beyond.
Please do add a sump gasket to your purchases and take the sump off and clean it out inside, this is a good opportunity to find out if dire things are happening as is usually evidenced by metal fragments, clips and pins being found int he sump. Please note that the sump gasket does not need ANY sealants, adhesives, or magic potions to do its job, all it needs is a nice, clean mating surface. If you are having trouble getting it to stay in position whilst you offer the sump up to the engine prior to bolting it - a small smear of axle grease is the way to go.
Brakes.
Brembos have hard anodised, polished pistons and unless they leak when connected to a working master cylinder I'd be inclined to leave them alone other than fitting new pads, new stainless steel bleed nipples and some new rubber caps. I would count on replacing the hoses to the brakes as soon as practicable, this is a near 40 year old machine and they have had their life. Braided stainless steel lines are good.
Master cylinder
After the length of time your bike has sat, you can pretty much bank on the master cylinder being toast. Pull it apart and if the bore is undamaged, clean it up and put a new piston kit in it (and then go and buy a handful of lottery tickets). OTOH if the M/C is toast you have some decisions. If it is a "round" tank model, it is junk purely because you can no longer buy new tanks, I have several otherwise serviceable (or repairable) round tank M/Cs and I keep looking but cannot find new tanks. Even if yours is good it is still a time bomb as the seal at the base of the tank will fail and when it does it is game over because whilst it is just a simple O-ring, pulling the tank will destroy it 99 times out of 100.
If you have a square tank, then I'd buy a new tank (they are cheap) and O-ring, and possibly a new internal "baffle" (which are not cheap but are eventually ruined by brake fluid). Look on the front side of the M/C and it will have a number, most likely 12 or 13 which refers to its bore size. I would pay to have a square tank M/C sleeved in stainless steel before I'd buy a new one - the stainless sleeve will last forever and require only piston changes thereafter and will cost a lot less than a new M/C. There are some who say a sleeved master cylinder may leak - in which case it was done wrong. Correctly done the sleeve is frozen and pressed into a heated M/C body that has been previously bored to size - the resultant interference fit is NEVER going to leak. However, a brake cylinder rebuilder who does not have a precision lathe on the premises is likely going to use a bench drill and should be wearing a white cap and a black apron because he is a butcher, not an engineer.  Using a bench drill and adhesives works sufficiently often that many use that method and frankly with a sleeve going into a cast iron cylinder, yeah maybe. Into Alloy - no way......
If you do buy a new M/C, buy the latest brake lever as well, it may help you avoid a mismatch problem.
Fuel tank.
That needs to be cleaned and relined urgently. I've no knowledge of POR products, but a lot of people report positive results. A small tip. Once you have your new liner in the tank and you are about to put it aside to cure, lay it down upside down. The reason for this is that you inevitably end up with a "blob" of excess liner material and if that blob is always under fuel you run the risk of the fuel attacking it and getting through it to the steel and restarting the corrosion problem. Putting the tank upside down means the blob is permanently above fuel level and is less susceptible to attack.
Tank petcock.
Buy a rebuild kit, they are cheap. Also buy a new filter "sock" for it - that is the only fuel filter an airhead needs.
Carbs
Before spending a fortune on new parts, these carbs are VERY durable. If you have the "pissing fuel on your boot" problem, firstly turn your fuel tap off when you stop - your carbs are not petcocks (Bing told me so). If you have a persistent leak, take the float bowl off and jiggle the floats up and down a 1/2 dozen times and see if that cures it. This can take a while, I foolishly let my fuel system dry out and when I went for a ride last weekend I had to stop 11 times and do as above until all the crap in the fuel lines was flushed through. Obviously if you still have problems after the above, put a kit through your carbs. Do not wimp out on replacing he butterfly shaft o-rings, they are important. Do one  carb at a time as many components are "handed" - mixing handed components is bad....Very bad.
Further rant later.
Mrclubike
Reply #14 - 09/26/18 at 20:23:05
You will have to dissemble the caliper and measure the piston  to know for sure what kit you need
All of these Brembo  calipers look the same but have different piston diameters
« Last Edit: 09/26/18 at 21:26:22 by Mrclubike »
Mrclubike
Reply #15 - 09/26/18 at 20:24:45
Hopefully it will measure 38mm and you can get the very inexpensive Brembo 38mm kit
here is the link to the complete caliper if yours are to far gone
They are standard Moto Guzzi parts
http://www.mgcycle.com/index.php?main_page=product_info&cPath=110_115&products_i...
Mrclubike
Reply #16 - 09/26/18 at 20:27:42
The ATE is  what you  had originally
Like yours I have installed a standard 38mm Brembo F08 in its place
Barry
Reply #17 - 09/27/18 at 03:40:18
Matt Chapter wrote on 09/26/18 at 09:37:47:
Looks to me like the Power King PK-12180 replacement batteries are AGM's.
TomHoldom
YaBB Newbies
Reply #18 - 09/27/18 at 13:12:29
Thanks all again,
OIL
stripped drive shaft fill - obviously needs a repair in the long term.....presumably that means taking apart to get access to drill out etc?
Having finally managed to remove the plug from this location (previously it was just turning), is there a temp / bodge fix I could get away with in the  short term...?
the oil filter I have taken out is the 'bendy' 2 part type, but I am ordering the 'straight' type to replace - is this ok?
Oil that came out of the engine was 'clean' looking, so I don't think I'll remove
FRONT BRAKE CALIPERS
got the calipers apart; condition doesn't look too bad? (see photos), the pistons aren't jammed, I can compress both sides and a bit of residual fluid gurgles - should I be able to remove them?
They appear to measure 36mm diameter - is this bad news? I think someone mentioned the 38 was more commen and cheaper for parts?
That said the condition doesn look bad, but as you know I'm no expert; could you have a quick look at the photos and tell me what you think - pads have still got plently on them......
MASTER CYLINDER
Got this apart, but things here look less good - see photos...salvagable?
Its maybe looking like I'll have to 'upgrade' to a square. Motobins tell me that part 61126 THROTTLE ASSEMBY WITH MASTER CYLINDER is compatible with my twin disk brembos - at cost of £258,60....! May be the way to go?
TomHoldom
YaBB Newbies
Reply #19 - 09/27/18 at 13:34:12
and a couple of master cylinder photos
Aethelric
YaBB Newbies
Reply #20 - 09/27/18 at 14:50:11
In parallel:-
Mine is a 1985 R65LS bought 25 years ago, used on an off for 10 years then left 15 years (undercover) and now am getting going again.
Battery was dead but hooking up to a leisure battery it sputtered into life.
Mine is now in bits, Engine out, barrels and heads off being aqua blasted, frame awaiting powder coating.  Bottom end looks in good shape.
Mrclubike
Reply #21 - 09/27/18 at 21:40:16
take the pistons completely out to measure
Maybe the outer  rim is smaller than the piston itself
That fluid looks really bad
Looks like water contamination
I suspect the MC bore is bad
I suspect the caliper bores are pitted also
TomHoldom
YaBB Newbies
Reply #22 - 09/28/18 at 03:46:18
Hello Mrclubike,
any tips on how to get caliper pistons out - as I say, they move in and out, but I'm not familiar with these bits, so I'm nervous about damaging something.
Attached is a photo of the MC bore and piston after a soak in some slightly less old fluid - Look slightly less awful, but I'm thinking with the amount other dodgy bits with this MC; reservoir cap screws had to be drilled out as 2 out of 3 were spinning without coming out, diaphragm knackered, fluid leak even before I stopped using the bike 12 years ago, etc.... that it might be sensible to renew for the square reservoir?
Barry
Reply #23 - 09/28/18 at 03:55:47
A bit late now but I would have pumped them out before draining the fluid.  I've refilled the system before now to get a stubborn one out.  Other methods include using compressed air taking care the piston doesn't become a missile.
YaBB Administrator
I love my Beemers
Reply #24 - 09/28/18 at 16:21:52
Put a piece of wood in place of the "rotor" and put some compressed air to the inlet.  Make sure your fingers are clear when doing this...
WWW
Tony Smith
Reply #25 - 09/28/18 at 19:05:59
If the caliper pistons are really stuck (and being Brembos I'd be surprise if they were) You can run a tap into the gallery that connects the two halves of the caliper and fit a grease nipple.
Using a grease-gun to pump out stuck caliper pistons is something I have done many times, mostly to car brakes, but also to ATE and Tockico calipers (manufacturers who share the unspeakable crime of using chrome plated bright mild steel for pistons).
Messy, but never yet met a piston that successfully resisted.
However, to turn to your immediate problem, I would simply fit an O-ring and put your calipers back together and give them a good flush once you have a working master cylinder. A motorcycle wrecker of my acquaintance tells me that he has seen Brembos sit on his shelf for 20 years and still be useable.
Don't panic about possible bore damage, such damage will likely be on the fluid side of the seal and therefore irrelevant. Spend your time and money on more urgent projects.
TomHoldom
YaBB Newbies
Reply #26 - 10/02/18 at 10:50:05
Hello again
BREMBO CALIPERS
Finally got my calipers pistons out - good news is they look in good condition, less good news is they are 36mm so when I come to need parts it'll cost more...
At the moment I'm just planning to buy new s/s bleed nipples and rubber caps (as recommended by Tony Smith)
MASTER CYLINDER
Looks like this is beyond my powers of repair, so planning to order a new throttle assembly with master cylinder
STRIPPED DRIVE SHAFT FILL
Barry, I've looked at the heliocoil kits - much simpler than I first imagined. Do you know which thread I need - looks like M12, but there is M12 x 1,5 x 16,3 kit or M12 x 1,25 x 16,3 see photo below; do you know which one of these might do the job?
Presumably I'll need to remove the rear suspension spring for access?
MOTOBINS
see below for a list of items on my motobins order I will placing in the next couple of days; let know if you think I should be considering anything else.
Thanks again - all comments appreciated
Tom
Barry
Reply #27 - 10/02/18 at 13:55:52
TomHoldom wrote on 10/02/18 at 10:50:05:
It'a 12 x 1.5.
I've never had to do this but when you get the drive shaft filler plug out you'll see there is very little depth of free space below the threads to use any sort of taper tap and even if there was you would have to devise a means of preventing swarf getting into the housing. Perhaps someone who has done this repair will chip in and say if it's possible in situ or if as I suspect the drive shaft will have to be removed. I think I'd want to use a pillar drill to keep the hole and threads perpendicular to the housing.
Tony Smith
Reply #28 - 10/02/18 at 15:03:45
Barry wrote on 10/02/18 at 13:55:52:
It is not possible to do in situ. More to the point, unless you are very,very lucky there is no little metal there that a "proper" repair may require welding and re-drilling.
My wife's bike has been wearing a rubber bung in place of the "fill" screw since the early 90s. Water doesn't get in and only a little gear oil manages to migrate out to remind me that one day I must get  a round to fixing it properly. I am about to pull that final drive to replace seals and at least the big bearing (and on past experience probably every bearing bar the input "sleeve" bearings which just never seems to fail on the older airheads). As I will have it stripped to a bare housing I'll take it into town and have it welded and drilled for a new bolt.
YaBB Administrator
I love my Beemers
Reply #29 - 10/02/18 at 16:01:25
The repair I did I drilled and then used a "bottoming" tap and JB-Welded the insert into the final.  On the drill and tap just use a bunch of sticky grease and most, if not all, of the chips will stick to it.
WWW
Mrclubike
Reply #30 - 10/02/18 at 21:00:27
I think I wold try to go towards a repair Like Justin suggested
See if you can drill the original plug out big enough to allow it to be used as a thread repair insert and just JB weld it in
You may be able to drill   it  out enough to get a 8mm bolt in it
Darn Helciols can be tricky
Tony Smith
Reply #31 - 10/03/18 at 03:21:02
Mrclubike wrote on 10/02/18 at 21:00:27:
If I were to even try to do this I'd use a cut down tinesert rather than a helicoil.
Barry
Reply #32 - 10/03/18 at 06:28:02
Justins repair was very neat. You are only going to be putting a maximum of 150 cc of oil in so it doesn't need a big fill hole.
TomHoldom
YaBB Newbies
Reply #33 - 10/03/18 at 06:59:55
Hi Tony,
I think I'll go down your 'temporary' rubber bung solution for the time being. Just trying to source the right one - do you think a tapered rubber bung 9mm diam and 11,5mm diam x 20mm ht would be about right?
I'll add Justin's or the Helicoil solutions to my phase 2 list.....
For cleaning up the calipers, do I use break fluid and an old toothbrush?
tunnelrider
Senior Member
Reply #34 - 10/08/18 at 01:05:42
Just adding a post to bring this topic back to the current board as it was before I deleted a post I made, to start a new topic.  Somehow Tom's R65 resurrection topic disappeared off the board too.
 1985 Black R65  -  1983 Ducati Pantah 500 - 2001 DRZ400 dirt only
Tony Smith
Reply #35 - 10/08/18 at 02:12:38
TomHoldom wrote on 10/03/18 at 06:59:55:
Hi Tony,
If the bung fits tightly whilst still leaving enough material on top for you to grab when you need to remove it, it will be golden.
I've attached a photo of the "bung" in the final driveon the wife's R65/80, ignore the oil weep marks, I am going to rebuild it this week, for some reason I've had to do 3 final drive rebuilds this year, which is more than I've had to do in the previous 40 years of Airhead onwership. The only thing I'll say is that I am now a dab hand at getting the little bastard of a bearing out that carries the "nose" of the pinion shaft, I've borrowed from the old mechanic's cookbook for removing the clutch bearign or bush from the centre of a flywheel - turn up a piece of steel that just fits inside the bush/bearing and then pack as much grease as possible into the bush/bearing. Insert turned steel drift and then smack the end of it smartly with a big hammer, the grease, having nowhere to go, forces the bush/bearing out.
As to cleaning the caliper - whatever floats your boat, just be sure that when to put it back together that you only use clean brake fluid as assembley lube.
TomHoldom
YaBB Newbies
Reply #36 - 10/08/18 at 05:58:47
thanks Tony
DadsR65
YaBB Newbies
Reply #37 - 10/11/18 at 05:31:41
Hello again
Tom
I did this repair.  Here's the final result:  https://advrider.com/f/threads/new-airhead-project.1260761/page-3#post-33742346
Read up a bit in the thread to see how I did it.  No leaks to date.
TomHoldom
YaBB Newbies
Reply #38 - 10/16/18 at 10:34:13
just got my other front disk brake pads out, and this set also have a decent amount of pad left, though a bit more rust/flakey paint on the rear side - is this something to worry about, or can I re-use.
If I need to replace, how can find the correct replacements for 36mm Brembo Calipers?
see photos
TomHoldom
YaBB Newbies
Reply #39 - 10/16/18 at 10:43:58
Tyres:
should I also assume that tyres have to be changed
see photos
I see these are suggested as a not to pricey option
Rear Tyre
Metzeler ME77 - CLASSIC
SIZE: 4.00 -18 64H
Front Tyre
Metzeler ME22 - CLASSIC
SIZE: 3.25-18 59P reinf.
any advice appreciated on these
(my usage will be occasional mainly taking it easy around country lanes)
Barry
Reply #40 - 10/16/18 at 13:38:54
Nothing wrong with the original quality of those tires but how old are they ?    You should be able to work it out from the date codes on the side wall.
Barry
Reply #41 - 10/16/18 at 13:42:42
TomHoldom wrote on 10/16/18 at 10:34:13:
In terms of wear those pads are nearly new so I would be inclined to clean them up and repaint the backs.
MrTall100
YaBB Newbies
Reply #42 - 10/19/18 at 13:41:05
Hi,
Might not be of help now but although really really expensive the 16mm master cylinder from Motorworks fits the lever assembly on a 78-80 R65 which has the round reservoir.
I bought a ‘reconditioned’ lever and master cylinder assembly on eBay, only to find it leaked straight away which meant I had little options  Cry
Andrew
MrTall100
YaBB Newbies
Reply #43 - 10/19/18 at 13:42:08
Sorry mean’t to say twin disc although they sell other sizes.
Tony Smith
Reply #44 - 10/19/18 at 16:03:47
My GOD!
The only time an R65 would need a 16mm master cylinder is if you were fitting Brembo 4-spot calipers.
I did the math when I was considering doing just that, BMW use a 17mm or 19mm for those calipers depending on whether you have a K100, K1100 or R1100/1150 and the consensus is that they can be just a little wooden.
I worked out that 16mm gave a nice ratio and 15mm  would be OK once the hand learned moderation.
16mm with Brembo F08s would require horrendous lever pressure in order to work, 13mm is about right for most people, I am currently running twin K100 sourced Brembo 2-spots o a 12mm master cylinder and whilst I'll admit it took a ride or two for the hand to learn moderation, I am now completely happy with it (moderation required because 1 finger can lock the front wheel without raising a sweat)
TomHoldom
YaBB Newbies
Reply #45 - 10/20/18 at 01:39:40
Thanks Barry,
I've got the DOT refs here; the front is 497, which must be 49th week of 1997, and the rear 499 being the end of 1999........
MrTall100
YaBB Newbies
Reply #46 - 10/20/18 at 02:48:34
Yes Tony, wooden would be a good description on how the lever feels especially with the SS lines fitted.
Having spent a small fortune on the brakes inc replacing the calliper seals and lines it will have to do for a while. It’s never going to be a daily ride.
Leaving old fluid in them sitting for years is what probably kills them as not been on the road since 2008.
Barry
Reply #47 - 10/20/18 at 04:33:00
TomHoldom wrote on 10/20/18 at 01:39:40:
Thanks Barry,
You'll want to change them then !
I had those 3 digit codes on my 79 when I bought it at 28 years old and only 6000 miles.  The problem with the 3 digit codes was you couldn't tell which decade they dated from. The front was so rock hard it was obviously original and I replaced it immediately but the rear looked good with no cracks and had so much tread left I initially thought it was a later tyre and rode on it for several thousand miles. When it refused to wear out I changed that as well.
TomHoldom
YaBB Newbies
Reply #48 - 10/20/18 at 07:30:58
ok. These seem reasonably priced in France - d'you think they'll be ok?
Rear Tyre
SIZE: 4.00 -18 64H
Front Tyre
TomHoldom
YaBB Newbies
Reply #49 - 10/20/18 at 07:46:51
Any tips on getting the last bolt undone to get my calipers apart?
Tony Smith
Reply #50 - 10/20/18 at 15:36:56
Put them back on the bike and then jump on that extension bar you have there, after first soaking it with a 50/50 mix of Acetone and ATF for a few days.
A bit of heat would probably help the process too.
Replace bolts with Stainless Steel ones and use anti-seize on them.
davidpdx
Full Member
Reply #51 - 10/22/18 at 10:30:24
I didn't see that anyone had mentioned new tires. When I bought my bike it had 10 year old tires on it with less than 1000 miles on them. The bike was so squirrelly that I though that I had forgotten how to ride a motorbike. New tires and shocks made a world of difference. Lesson learned, tread depth is not the only thing to check. The month and year of manufacture is stamped on the side of the tire if you look long enough.
1984 R65 60K+
1946 Triumph Speed Twin
Being shot out of a cannon will always be better than being squeezed out of a tube.  That is why God made fast motorcycles, Bubba…
— Hunter S. Thomps
YaBB Administrator
I love my Beemers
Reply #52 - 10/22/18 at 23:06:49
Yeah, tires are close to the top of my list of things to change on a "new" bike.  The last three used motorcycles I've had had a head-shake at about 40 mph that was "fixed" with new tires...
WWW
TomHoldom
YaBB Newbies
Reply #53 - 10/24/18 at 11:01:43
anyone care to comment on these as replacements?
Rear Tyre
SIZE: 4.00 -18 64H
Front Tyre
davidpdx
Full Member
Reply #54 - 10/24/18 at 22:01:45
Metzelers are spendy tires but I have ridden on bad asphalt in rainy near freezing temp and they have never gone out from under me so I am pretty much sold. The old rock and roll song "the brakes are good, the tires fair" kind of doesn't make it on two wheels. But I still like the song.
1984 R65 60K+
— Hunter S. Thomps
TomHoldom
YaBB Newbies
Reply #55 - 11/17/18 at 04:27:44
Oil filter change.
I'm just fitting my replacement oil filter and have 2 spare washers from the motobins kit - see photos - are these necessarily required?
Aethelric
YaBB Newbies
Reply #56 - 11/17/18 at 04:54:32
I'll be interested too.  I could not find a place for the big metal "shim" either.  Nothing like that came out of the old one.
TomHoldom
YaBB Newbies
Reply #57 - 11/17/18 at 05:33:42
also replacing washers to the various sumps.
replacements are copper with a rounded profile, and originals are flat edged aluminium - see photo.
Am I doing the right thing?
Got  a torque setting for the gearbox sump, but nothing given for the engine oil (which is an allen key, so difficult any way to hook up to my torque wrench....) Not too tight a suppose?
Barry
Reply #58 - 11/17/18 at 11:30:15
I'm sure the copper crush washers will be fine.
BMW's spec for the sump plug torque is something like 22ftlbs which I consider dangerously high. I go very light with 10 ftlbs for all the fill and drain plugs except the drive shaft which gets a bit less and I've never had one leak or fall out.  You could probably safely go a little higher than 10 but I wouldn't dare use 22 ftlbs. I'd be interested to hear what others use.
Bob_Roller
Global Moderator
  GMT -7 Hours
Reply #59 - 11/17/18 at 12:50:48
The large metal washer, commonly called a shim, goes into the oil filter cavity, it sits on the edge of the sleeve in the filter area .
As far as tightening the various fill and drain lugs, you need a light touch with the wrenches, etc ...
You'll find out real quick, that steel fasteners and aluminum threads can become a disaster if over tightened .
skippyc
Senior Member
Shouldn't have sold them
old bikes.
Reply #60 - 11/17/18 at 15:30:49
Copper washers are good they seal with less torque.
I found no use for the smaller oring either.
Mrclubike
Reply #61 - 11/17/18 at 19:04:33
Aethelric wrote on 11/17/18 at 04:54:32:
Just because you didn't remove a part when you dissembled it doesn't mean you don't need it
Previous owners are notorious for screwing things up   Angry
The large diameter shim in the kit is critical in some applications
If your engine requires it and you leave it out  you can have loss of oil pressure and destroy your engine
I do not know the cut off dates of when it is and isn't required
But a simple search of the "2000 dollar O ring" will tell you all about it
But the best info is here at Snowbums tech articles
http://bmwmotorcycletech.info/technical-articles-list.htm
After you are there scroll down to the Mechanical section and then to Line 51a
Every Airhead owner should be aware of the issue with properly  installing an oil filter
Bob_Roller
Global Moderator
  GMT -7 Hours
Reply #62 - 11/17/18 at 20:52:55
Looking at the o-ring assortment, I think the smaller black o-ring, may be for the oil dipstick .
Aethelric
YaBB Newbies
Reply #63 - 11/18/18 at 07:44:02
Thanks for that mrclubbike. Checking on Antons site it seems I need the shim, but not the gasket.(Canister depth is 3.5mm) When I dismatled it there was a gasket but no shim.
The old O ring (black not white in my case) had obviously been installed with some sort of sealant. So it is now reassembled with no gasket, and one shim, torqued up to hand tight with a T spanner and loctited (I don't believe in lock washers.
The black 30mm O ring fits the filler plug and the 20mm copper crush washer fits the drain plug.
Bob_Roller
Global Moderator
  GMT -7 Hours
Reply #64 - 11/18/18 at 13:06:10
None of the fill or drain plugs use a rubber o-ring, they all use metal washers .
Mrclubike
Reply #65 - 11/18/18 at 23:33:53
some Dip sticks use the Oring
Mrclubike
Reply #66 - 11/18/18 at 23:35:52
Aethelric wrote on 11/18/18 at 07:44:02:
Very glad you Fixed it  Grin
TomHoldom
YaBB Newbies
Reply #67 - 12/01/18 at 04:17:37
Hello Again -
my new SLA battery has arrived and I want to check whether I will be ok using my 12 V car basic car battery charger (bought from halfords around 10 years ago).
Read about risk of damage if over charged
Thanks
Barry
Reply #68 - 12/01/18 at 04:32:14
The only thing thing to worry about on a sealed battery is continuing excessively high charge voltage once the battery has reached full charge.
A wet cell battery will gas once fully charged but a sealed battery will eventually vent on the pressure relief valve which will shorten it's life.
So you can use any charger on an SLA battery provided you monitor charge voltage and don't allow it to exceed the manufacturers recommendation. In the absence of a manufacturers figure 14.5 volts would be safe.  And then when it reaches full charge take it off.
Conversely leaving an SLA on an unregulated charger which might easily reach 16 volts or more once the battery reached full charge would be the kiss of death.
TomHoldom
YaBB Newbies
Reply #69 - 12/01/18 at 06:51:50
ok thanks Barry
I wont leave too long.
Any idea how long a first charge might take, and can I rely on the 'ready' indicator light as a safe voltage check, or would I be better off using a voltmeter?
Barry
Reply #70 - 12/01/18 at 09:14:30
If the charger has a ready light then it's not an old unregulated type so it should be safe.   It's right to charge a new battery before putting it into service but it shouldn't need much at all.
TomHoldom
YaBB Newbies
Reply #71 - 01/10/19 at 11:31:21
I'm about to order my tyres from my 1978 R65 and wondering whether I need to be concerned about not have a 'matching' pair
I don't want to spend too much and at the moment I'm hesitating between:
Front tyre: Metzeler ME22 90/90 - 18 (57P) (€29)
Front tyre: Metzeler ME22 - 3.25-18 59P. (€39)
Rear tyre: Metzeler LASERTEC 110/90 - 18 (61H) TL (€88)
Rear tyre: Metzeler PERFECT ME77 4.00R18 64 H (€89)
(existing old tyres are,  front: 90/90 - 18.51 H & rear: 120/90 H18)
Thanks
Tom
Tony Smith
Reply #72 - 01/10/19 at 14:50:39
TomHoldom wrote on 01/10/19 at 11:31:21:
rear: 120/90 H18)
You may well fid that to fit a 120/90 that a modified spacer kit has been fitted to the rear wheel to move it to the left somewhat. Nothing wrong with that except that if the drive splines in the hib and wheel have taken a "set" it isn't really reversible.
TomHoldom
YaBB Newbies
Reply #73 - 01/17/19 at 01:46:01
ok thanks Tony, I'll have a look for that - if I upload a photo of the rear wheel would you be able to tell whether a spacer has been fitted?
Is the issue of having a matching pair important - the website I was looking to buy the tyres said I have to have a matching pair?
Tony Smith
Reply #74 - 01/17/19 at 06:02:50
You will need to measure the spacer to see if it is longer than standard - not a difficult task.
Tyres that are meant to be used as a pair should be used as such. The problem is sorting out tyres that are genuine pairs from those that are marketing hype.
Some 120/90s will fit, some will not. Unfortunately with the steady disappearance of "inch" tyres and the ever bigger tyres being fitted to new bikes the 110/90 which is a pretty much guaranteed fit has all but disappeared, other than for really ghastly tyres like Shinko.
