Normal Topic 79 R65 Clutch screw torque value (Read 129 times)
Jschara
YaBB Newbies
10/31/18 at 07:59:58
Can any one tell me what the clutch screws on my 1979 R65 should be torqued to?  Clymer BMW 500-1000- 1970-1982 says 17 ft. lb. I know thats not right because I just snapped one.  Time to reorder some more screws!
Thanks in advance,
Jim
wilcom
Re: 79 R65 Clutch screw torque value
Reply #1 - 10/31/18 at 08:09:45
Here's a link to Snow Bum's torque page, could be of value.
http://bmwmotorcycletech.info/torquevalues.htm
1979  R65
1980  R65
1972  R75
1964 R50
Burt
Full Member
Reply #2 - 10/31/18 at 08:11:01
That's the same figure I have in the Haynes manual.
Black 1984 R65 - the Wombat
georgesgiralt
Reply #3 - 10/31/18 at 08:56:37
Of which clutch screws are we speaking ?
On the flywheel ?
Tony Smith
Graduate, Wallace and
Gromit School of Engineering
Reply #4 - 10/31/18 at 09:59:09
17 in/lbs would be closer for the 8mm thread.
Barry
Reply #5 - 10/31/18 at 11:00:43
Clymers and no doubt Haynes copied the 17 ftlbs from the original BMW workshop manual but it's wrong and probably intended for the 8 mm screws used on other airheads.
For your 6 mm screws you only need 7-8 ftlbs.
There are a few mistakes in the BMW manuals which get taken up by the likes of Clymers and Haynes so you can't necessarily trust any of them.  If a recommended torque value seems high always cross check against a standard table for the size and spec of fastener in question. Ironically the very first pages in the BMW manual include standard torque tables although with immense stupidity that can only be the result of men in white coats they give the torque values in units of Mkp which is equivalent to 9.8 Nm or 7.2 ftlbs.
Jschara
YaBB Newbies
Reply #6 - 10/31/18 at 15:54:39
Thanks to all for the quick reply.
Sorry georgesgiralt I should have been more precise.  The six screws that hold the clutch pack to the fly wheel.
Jim
Bob_Roller
Global Moderator
  GMT -7 Hours
Reply #7 - 10/31/18 at 17:39:54
I have a factory shop manual, it was charts for standard torque values for bolts and nuts .
For 6 mm bolt diameter, there a various torque values for different property classes of bolts .
The lowest value is 4 ft/lbs, the highest is 11 ft/lbs .
I'd say Barry has correct values for torque .
