Page Index Toggle Pages: 1 2 [3]  Send TopicPrint
Very Hot Topic (More than 25 Replies) stainless steel braided brake lines (Read 1538 times)
Tony Smith
Graduate, Wallace and
Gromit School of Engineering
Re: stainless steel braided brake lines
Reply #30 - 01/31/19 at 15:48:22
davidpdx wrote on 01/31/19 at 13:34:22:
I also wounder about how difficult it is to re-sleeve it down to a smaller size as I have a good working master cylinder now.
Easy job if you have the machine tools, the hardest part is setting up the correct level of interference so that brake fluid doesn't leak out between the cylinder body and the sleeve.
Even if you pay a brake shop to do the sleeve it will still be cheaper than the cost of a new master cylinder.
davidpdx
Full Member
Reply #31 - 03/29/19 at 20:28:35
Well the R65 forum does it again. After putting new braided brake lines and organic pads on I was still not satisfied with my front brake. It turns out I had a 15mm master cylinder mounted. Thanks to Mrclubike and Tony for explaining the need for a smaller MC I bought a 12mm off a wrecked R65 and mounted it today. I can't quite lock up my front tire but it dives down hard and scrubs the speed off nicely. Thanks for all your help guys, what a great resource. You may not have saved my life but then again you might have. David
1984 R65 60K+
1946 Triumph Speed Twin
Being shot out of a cannon will always be better than being squeezed out of a tube.  That is why God made fast motorcycles, Bubba…
— Hunter S. Thomps
Mrclubike
Reply #32 - 03/29/19 at 21:46:28
You are Very Welcome
glad to help  Smiley
