Normal Topic 12 V Heated gloves for a 1983 r65 LS (Read 139 times)
jp9094
Junior Member
12/08/18 at 16:01:09
As winter is upon us here in the NE USA, I wanted to check out some heated gloves. However I am not sure if the electrical system on the bike can handle  them. I was looking at some Gerbring models, but could not find the current draw on the sites I looked at. The whole electrical system (Diode board, voltage regulator, rotor etc.) was changed in 2015. Any thoughts appreciated.
T.I.A.
wilcom
Re: 12 V Heated gloves for a 1983 r65 LS
Reply #1 - 12/08/18 at 16:39:14
I have Gerbing heated gloves @ 30 watts and  Gerbing Jacket/jacket liner @ 80 watts....
MY ignition switch has a spot where I can run with no Headlight if there is an issue. There isn't much that is compelling enough for me to ride at night needing heated gear Cool
1979  R65
1980  R65
1972  R75
1964 R50
Mrclubike
Reply #2 - 12/08/18 at 23:19:16
You should not have a problem with running gloves even with your head light on
If you want to run  gloves and a vest at the same time it will be marginal
If you switch all of your bulbs to LED you will have no problem at all running gloves and the vest
I can run a heated vest heated grips and  Aux  LED Flood light plus all the stock LED lighting with no problem
LED bulbs make High output charging systems almost obsolete
Barry
Reply #3 - 12/09/18 at 04:18:29
I just about get by down to -5 C  by heating my ordinary gloves and liners on a hot radiator before I set off on a 4 mile commute to work.  Any further than a few miles would make heated gloves essential though.
R65Guy
Full Member
I'd rather be ridin'
Reply #4 - 12/09/18 at 20:44:17
Things that help:
A good PWM type heat controller
Handguards
ATV Mitts / Hippo Hands
With handguards and ATV mitts I find I rarely use electric gloves anymore - they are just too bulky.
81 R65 & 16 R1200GS
