Normal Topic Wiring for rev counter (Read 128 times)
Sharky
YaBB Newbies
01/28/19 at 07:19:40
The rev counter on my bike wasnít working when I bought it, and with looking inside Speedo housing I found the rev counter wiring disconnected. Any idea which wire goes where to the spade connectors?
1986 R65 mono
georgesgiralt
Re: Wiring for rev counter
Reply #1 - 01/28/19 at 15:04:11
Hello,
I've found on an old French service bulletin the wiring of the electronic tacho to replace the mechanical one.
The tacho has 3 wires : Red is +12 V Brown is ground and green is impulse from the ignition.
With a multi-meter you should be able to find where are the first two going and, then, find the place for the third...
Hope this helps.
Sharky
YaBB Newbies
Reply #2 - 01/29/19 at 04:14:45
Thanks for info, Iíll give that a go.👍
1986 R65 mono
