Page Index Toggle Pages: 1 [2]  Send TopicPrint
Hot Topic (More than 10 Replies) Bolts for clutch removal tool (Read 487 times)
John M
Full Member
Re: Bolts for clutch removal tool
Reply #15 - 02/02/19 at 15:17:05
Also purchase a new throughout bearing for the clutch pushrod  . Examine the pushrod for any scarring and if it looks good just polish it with crocus cloth
1984 R 80 ST ,  1986 R65 ,2012  Vstrom, 82 goldwing. past bikes 350 and 500 cc velocettes, 250 BSA starfire,350 Kawasaki triple, CB500-4,               67 motoguzzi v7
John M
Full Member
Reply #16 - 02/02/19 at 15:18:06
Also purchase a new throughout bearing for the clutch pushrod  . Examine the pushrod for any scarring and if it looks good just polish it with crocus cloth.
John M
Full Member
Reply #17 - 02/02/19 at 15:41:34
Check out Motobins, for any clutch pushrod and related parts .They are very good to deal with .  My memory re all of the parts in the clutch pushrod assembly is 8 years old and not reliable as that was the last time I had one of mine apart ..Talk to Damien at Motobins ,he is very good.
Soeren
YaBB Newbies
Reply #18 - 02/03/19 at 12:44:33
Thanks John. Im very familiar with motobins, I'v gotten quit a lot of stuff from them over the years.
Just to be 100% sure before I start ripping out seals.
This is the clutch pushrod oil seal right?
https://photos.app.goo.gl/rv5EzZDNjZFp3xLk8
No. 15 in this blowup.
And, I cant seem to get the clutch assmebly off. All 6 bolts are out, I tryed heating it a little, and give af few gental taps with a hammer, but it wont budge.
'83 BMW R65
John M
Full Member
Reply #19 - 02/03/19 at 15:14:18
#15 is not a seal that is the inner race of the pushrod bearing
Mrclubike
Reply #20 - 02/03/19 at 20:14:25
Soeren wrote on 02/02/19 at 13:58:55:
When I removed the transmission I noticed a smalle rubber ring and a spring seal tangled together next to where the clutch control enters the transmission.
I tryed to identify it in the realoem parts fiche, but can't find it.
https://i.imgur.com/J2LIO2n.png
What is it, and has more of it dropped into the transmission?
i think this the seal you are looking for
John M
Full Member
Reply #21 - 02/04/19 at 03:13:33
that seal is at the opposite end of the transmission (front).
Mrclubike
Reply #22 - 02/04/19 at 20:20:58
This is the seal at the front of the input shaft on the  OD
Soeren
YaBB Newbies
Reply #23 - 02/05/19 at 14:19:18
Mrclubike wrote on 02/03/19 at 20:14:25:
Yes this is it, after I wiped it down I found a tear in the lip and I want to replace it. How do I best go about getting it out, can I get it out with a pick tool?
I have a set of these:
'83 BMW R65
Tony Smith
Graduate, Wallace and
Gromit School of Engineering
Reply #24 - 02/05/19 at 17:10:31
Most people use a suitably sized screw driver and (maybe) a rubber mallet to remove small seals. Learger seals are usually easily removed by running self tapping screws partially in around the periphery and then using a screwdriver or a claw hammer to lever them out using the screw heads.
To put seals in, a socket of about the same size and a rubber mallet usually works. But for big seals (for example the rear main seal) a proper tool is advised.
If you are a person that must have the "correct" tool, these are good examples of ways to spend money:
https://www.ebay.com.au/itm/10-Pcs-Bearing-Race-Seal-Driver-Installer-Set-Remove...
https://www.ebay.com.au/itm/12-Rubber-Seal-Puller-Remover-Oil-Grease-O-Ring-Grom...
PS - for my sins I own both of the above.
This one however is money well spent:
https://www.cycleworks.net/index.php?main_page=product_info&products_id=18
It will also set the big seal in the final drive.
