Normal Topic Torque val˙es for 1979 R65 (Read 137 times)
Jschara
YaBB Newbies
06/15/19 at 16:37:32
Can anybody confirm if these settings are right.
Drive shaft bolts 32NM
Swing arm pins 10NM
Swing arm nuts  105 NM
I got these from Chris Harris's Utube site.   I don't have a shop manual for my bike and I don't trust the Clymer 500-1000cc Twins 1970-1982 manual that I do have.
Thanks in advance,
Jim
Jschara
YaBB Newbies
Re: Torque val˙es for 1979 R65
Reply #1 - 07/02/19 at 17:33:49
Am I the only one out there that is concerned about torque?
Bob_Roller
Global Moderator
á GMT -7 Hours
Reply #2 - 07/02/19 at 17:56:27
The BMW shop manual I have, shows 27+3 ft lbs for the 12 point driveshaft bolts .
Tighten the pin to 15 ft lbs, then back off and torque to 9 ft lbs .
I don't know the diameter and thread pitch, so I can't look up the standard torque value for the nut .
To convert Nm to Ft lbs, Nm X .737= ft lbs .
'82 R65 LS á
Jschara
YaBB Newbies
Reply #3 - 07/02/19 at 19:22:08
Thanks Bob,
Jim
Barry
Reply #4 - 07/03/19 at 08:20:48
This is from a post by Mike Valenti many years ago. He was meticulous guy so I would have no hestation in trusting the figures.á As bob said with the pivot pins go a bit higher and then back off and re-torque to the specified figure.á The trick is then not to allow the pins move while torqueing the locknuts.
