Hot Topic (More than 10 Replies) R65 barn find (Read 151 times)
Bill Conquest
Full Member
R65 barn find
07/09/19 at 12:43:48
Hi..I just acquired A 79 r65  that had sat for 10 years and taken apart .. I managed to get it all together and .. itís running !!  The only problem is the front disc brake system is shot and I canít find a master cylinder .. iíve had bad luck in the past with rebuild kits and would like to get a new complete master cylinder .. anybody know where to look ? Iíve checked pretty much everywhere I can think .
Thanks in advance
Bill
79 r65/75 r60/76r75/76r100
Matt Chapter
<insert witty remark here>
Re: R65 barn find
Reply #1 - 07/09/19 at 13:11:54
Your '79 will have had the round master cylinder, I believe.  It's NLA.  I think I've heard that the newer design rectangle will fit, but someone else might be able to verify.  You probably also have the early caliper design, can't remember the name, but the pistons are also NLA and likely to be corroded beyond saving.  Later iterations of the R65 have Brembo calipers.
Likely you will not be able to go back with original matching equipment, and you'll want to investigate switching to slightly newer brembos, and a suitable master cylinder to drive them.
I also believe the '79 is a single disc, once configured correctly this will probably be capable of stopping the bike reasonably.
'86 R65 with '84 motor ~66000 miles. †SS lines, Spiegler rotor, Progressive monoshock, Keihan silencers, a piece of Pichler fairing.
'76 CB400F ~26000 miles. †Weepy SS lines, big dent in the tank.
BPT
Re: R65 barn find
Reply #2 - 07/09/19 at 13:34:46
The calipers before Brembo were Ate, correct?
Barry
Re: R65 barn find
Reply #3 - 07/09/19 at 13:37:14
Original caliper on a 79 would have been an Ate and yes you will be much better off with a Brembo. Seals and dust caps  are available for the Ate but thay are quite expensive. The original master cylinder will have been 13mm for a single disc. The size used with the rectangular version was 12mm so don't expect to find a 13mm replacement. I wouldn't be looking for one anyway as the 12mm size was an improvement. Some have gone even smaller at the risk of excessive brake lever travel.
Tony Smith
Graduate, Wallace and
Gromit School of Engineering
Re: R65 barn find
Reply #4 - 07/09/19 at 17:21:47
The later "square" master cylinder will fit the 1979 handlebar "perch". But, you will also need the 81 on brake lever. If you  are staying with a single disc I would buy a new Brembo/Grimeca caliper and I would get the 12mm master cylinder. The ATE caliper can be rebuilt, but at commercial rates will cost the same or more than a new replacement. Motobins has all the parts you need.
tiggum
Junior Member
Re: R65 barn find
Reply #5 - 07/10/19 at 09:00:05
I have the brake lever from the original M/C (since replaced) on my 1983 R65LS, if it is needed.  You may have it for the cost of the postage.  If interested, send me a PM with address.
Tiggum
Tony Smith
Re: R65 barn find
Reply #6 - 07/10/19 at 20:39:14
One thing I forgot, the 1979 will have a pressure switch in the brake line - these rarely survive being left long term with old fluid in the line. If you need a new one they are readily replaceable at any good automotive store, they are a standard thread size - I cannot recall whether they are a "straight" thread or a tapered thread, but that will be obvious when you pull the old one out.
I recomend staying with the pressure switch as they are cheaper and more reliable than the perch mounted mechanical switch (*and depending on just how early your 79 is, you may not even have the mount for a mechanical switch.
Bill Conquest
Full Member
Re: R65 barn find
Reply #7 - 07/10/19 at 23:28:24
Thanks everyone for all the great input .. I have to go over all this information and figure out which way to go .
I did find an original round master cylinder ..new ..quite expensive .. and some stainless steel lines . Iíve got to check out the pressure switch that Tony mentioned as I havenít seen it  anywhere . As for the calipers Iím not sure they donít look too bad but I havenít checked them out yet ..
Meanwhile the bike runs pretty well except for the odometer not working ..
Many thanks for all the help
Bill
Barry
Re: R65 barn find
Reply #8 - 07/11/19 at 02:19:14
Pressure switch should be on a manuifold behind the headlight.
Bill Conquest
Full Member
Re: R65 barn find
Reply #9 - 07/11/19 at 13:05:09
Right.. there it is!.. any thoughts on repairing the odometer ?
Barry
Re: R65 barn find
Reply #10 - 07/11/19 at 15:00:33
The odometer has a common problem with a gear slipping on the shaft.
Mine does it a little but only when the bike has been stood in hot sun all day.
If you go back to mid June on this same board, there is a thread started on the slipping gear.
ged in oz
Full Member
Re: R65 barn find
Reply #11 - 07/11/19 at 16:11:44
Hi Bill, here is the link to the thread that Barry has mentioned above:
http://www.bmwr65.org/YaBB2.612/cgi-bin/yabb2/YaBB.pl?num=1557823481
If you scroll down through the thread long enough you will find another link that takes you an article that explains the procedure. Itís on an R100 clock, so access is different but the internals are the same.
You need to uncrimp the face of the R65 clock to get into it, but itís very soft material so itís easy enough to do. I got a small screwdriver blade under the crimp and then gently worked it around without distorting it too much.
You live in a very beautiful part of the World! I spent a few days in Kauai about 15 years ago. Breathtakingly beautiful.
Bill Conquest
Full Member
Re: R65 barn find
Reply #12 - 07/11/19 at 22:51:42
Hey thanks a lot you guys ... iíll check that thread and see if I can do it .
Yeah this is a beautiful island thanks
Got to be a little careful riding ..tourists tend to not look where theyíre going too well  because theyíre distracted by the nice scenery .. canít blame them 🌈
