Hot Topic (More than 10 Replies) R65 Turbo Configuration (Read 772 times)
Flea
YaBB Newbies
08/29/19 at 21:38:12
Used to belong to a gentleman who was big on building and restoring.
Picked her up upon his departure, so not much is known.
Hoping someone can identify this as a kit or is it custom?
Thanks!
Bob_Roller
Global Moderator
Online
  GMT -7 Hours
Re: R65 Turbo Configuration
Reply #1 - 08/29/19 at 21:50:52
Looks like a custom application .
Only other R65 I've seen with a turbo, was a kit from Luftmeister, one of these was up for sale in Flagstaff, AZ about 10 years ago .
Is the bike in running condition .
Flea
YaBB Newbies
Reply #2 - 08/29/19 at 23:12:45
Thanks Bob.
Not currently running. Engine turns over.
Going to get spark plugs tomorrow and strap a battery on to check.
Will keep fire extinguisher close.
wilcom
Re: R65 Turbo Configurationlo
Reply #3 - 08/29/19 at 23:25:18
Flea wrote on 08/29/19 at 23:12:45:
if you have problems, not sure if a mechanic or a plumber would be your first stop Roll Eyes looks like a /6?.... good luck, would love to hear it run
1979  R65
1980  R65
1972  R75
1964 R50
Flea
YaBB Newbies
Reply #4 - 08/30/19 at 21:12:19
Well, came back from Autozone with what I thought to be the correct spark plugs in 14mm diameter only to discover that they didn't fit!
The threads in the cylinder head look to be about 16 or 17mm. Will need to get my calipers from work and thread gauge to get the specs.
Can't find any other specifications on the net besides 14mm.
Plugs were NGK BP7ES p/n 1034
wilcom
Reply #5 - 08/30/19 at 22:04:38
Flea wrote on 08/30/19 at 21:12:19:
Run the serial number at Realoem.com and find out what bike you have. That front end doesn't look like a R65
1979  R65
1980  R65
1972  R75
1964 R50
Flea
YaBB Newbies
Reply #6 - 08/30/19 at 22:17:13
wilcom wrote on 08/30/19 at 22:04:38:
Can't believe I hadn't thought about that!!!
1977 R100/7T
The seller told me it was a 1979 R65 and that's what I've been basing my research off. I had tried to get a carfax using the serial with no luck so gave up on that.
the plot thickens
Flea
YaBB Newbies
Reply #7 - 08/30/19 at 22:23:37
So the R100 uses the same spark plugs in 14mm Diameter which will indicate that the existing heads are modified.
YaBB Administrator
I love my Beemers
Reply #8 - 08/30/19 at 23:09:08
What a monster!  Oh, just pickin' nits but the valve covers are on the wrong sides!
Good luck on sourcing the plugs.  Maybe the seller could shed some light on the plugs or was his "departure"  the more permanent type?
WWW
Flea
YaBB Newbies
Reply #9 - 08/30/19 at 23:36:31
Justin B. wrote on 08/30/19 at 23:09:08:
Permanent departure  Sad
wilcom
Reply #10 - 08/30/19 at 23:43:54
No plugs in it when you brought it home?
1979  R65
1980  R65
1972  R75
1964 R50
Flea
YaBB Newbies
Reply #11 - 08/30/19 at 23:46:02
wilcom wrote on 08/30/19 at 23:43:54:
None. The wiring is a birds nest.
Tony Smith
Graduate, Wallace and
Gromit School of Engineering
Reply #12 - 08/31/19 at 02:25:34
That thing is an abortion, nothing more or less. With a single cylinder each feeding a turbo of that size if it works at all you will have truly massive lag, and probably not that much boost anyway.
I'd take it all off and see what you could get for it all from the car boys and then use the money to see if you can build a working motorcycle.
Oh, and your rocker covers are on the wrong sides, please correct.
Lastly, that does not appear to be an r65 to me, the front end is /7 at its newest and possibly a lot older. The front cover is also a generation older than an R65 and the cylinders suggest a long stroke engine - actual capacity unknown until you pop a head and measure the bore.
Flea
YaBB Newbies
Reply #13 - 09/02/19 at 18:16:29
Thanks Tony.
I'll have to tear her apart this weekend and remove all the bits that aren't stock.
There's a Vetter Fairing that I also want to get rid of. Do people still want them?
Couldn't get an exact diameter of the spark plug holes, but its either a 16mm or 17mm 1.25 pitch. Couldn't locate any suitable plugs in that diameter during my brief search.
Anyone interested in following this adventure??
YaBB Administrator
I love my Beemers
Reply #14 - 09/02/19 at 18:58:53
I'm very curious how you make out on this project.  We have a section "Restoration Progress Logs" that would be perfect.  Wonder if you could put a threaded insert in it and use a standard plug?
I was really hoping you could get it fired up with the turbos on it, would have been wild and a very unique sound!
Yes, people still use Vetter fairings.
WWW
