Page Index Toggle Pages: 1 [2]  Send TopicPrint
Hot Topic (More than 10 Replies) Replacing the rotor disc & upgrading to 4 piston. (Read 601 times)
Matt Chapter
<insert witty remark here>
Re: Replacing the rotor disc & upgrading to 4 piston.
Reply #15 - 05/26/20 at 12:51:12
Mucci, do you have the dimensions for the braking rotor you got?  While I've got my caliper off I'm going to replace the rotor too, and I'm either going to replace just the rotor with a braking one, or get an EBC.
The EBC I'm looking at is https://ebcbrakesdirect.com/motorcycle/bmw/r80-r-80-rt-single-rotor/1984-1990/31...
Edit:  Did some looking, looks like the rotor for my mono shock is this one.  The twin shock rotor is 260mm, mine is 285mm, which checks out with my paperwork from Spiegler.
http://www.braking.com/catalogue/dettaglio_prodotto.php?codice_articolo=BW02FI
'86 R65 with '84 motor ~67000 miles.  SS lines, Spiegler rotor, Progressive monoshock, Keihan silencers, a piece of Pichler fairing.
Mucci
YaBB Newbies
Reply #16 - 05/26/20 at 15:01:37
Matt Chapter wrote on 05/26/20 at 12:51:12:
Do you still need dimensions from the 260mm rotor? Good to know they make a 285mm too!
qwerty123
Junior Member
Reply #17 - 07/04/20 at 21:11:03
I outline another plan (that I haven't implemented), that of moving from the stock 38mm caliper with single disk to a 48mm, here: https://www.bmwr65.org/YaBB2.612/cgi-bin/yabb2/YaBB.pl?num=1511573205/8#8
When I thought it through a while ago it was cheaper than the dual disk conversion.
Tony Smith
Graduate, Wallace and
Gromit School of Engineering
Reply #18 - 07/22/20 at 22:27:12
Great write-up, but you went to a lot more trouble than was necessary to remove the rivets from the old disc. Given that you are not goign to reuse the old disc I just deployed the angle grinder and removed the heads of the rivets (ad some of the disc), a pin punch removed them whilst still warm.
1978 R100RS| 1984 R65 | 1992 KLE500 | 2002 R1150GSA | 2019 DRZ 400
dogshome
Junior Member
Reply #19 - 08/02/20 at 18:28:48
Hi Mucci, I like the rotors and the write up. The only thing I would change is the bracing via the mudguard/fender.
Mine was quite sensitive to road imperfections until I fitted a dual loop steel brace. i was pretty sceptical that it would do anything, but it did.
So where you have spacers to fit the standard pressed brace, I can only imagine it give a little more flex.
I find the dual standard discs quite good, now rebuilt. My friend has a Harley Sportster with single disc (+100 lb of iron engine) and describes it as puny. I can imagine a single disc on the R65 is something in between.
He never goes much above 65MPH, so for him to complain about the brakes means it really isn't great!
