Hot Topic (More than 10 Replies) Whine,squeal, singing noise? (Read 190 times)
spiney
YaBB Newbies
07/24/20 at 17:05:17
1981 has a high frequency noise around 2-3 thousand revs not there on start up but quickly appears as soon as engine warms up. Sounds like its coming from the very front of the engine. I have replaced both rotor (not stator) and bean can but no change. There when stationary or underway pull in clutch lever no change. Have a mechanic mate with a lot of airhead experience but as he has a very steep industrial high frequency hearing loss he can't hear it very well?? Any ideas?
1981 r65
1976 90/6
wilcom
Online
Re: Whine,squeal, singing noise?
Reply #1 - 07/24/20 at 19:48:33
spiney wrote on 07/24/20 at 17:05:17:
Since it is soo hard to type a noise.........any chance of taking a video(with sound Smiley) and posting to Youtube so we could all have listen ?
1979† R65† †
1980† R65† †† †† ††
1982 R80RT†
1974 R90/6††† †
1972† R75† †† †††
1964 R50
spiney
YaBB Newbies
Reply #2 - 07/25/20 at 04:00:21
Yep I'll get a video with sound as soon as I can.
1981 r65
1976 90/6
Kelvin
YaBB Newbies
R65LS
Reply #3 - 07/25/20 at 16:07:51
I once had a noise that would answer that description after replacing the camchain. Squeaking at only a particular rev range, and only under power. Because I heard it only under power I only noticed it when riding the bike, not in the garage. The fact that you only observe it warm also suggests camchain: a worn camchain is often quiet on startup, only audible when warm.
Solution was to take the timing cover off and adjust the chain guide carefully.
How long since you've replaced the camchain? I would expect to do it at 80k km.
1983 R65LS 1985 to 1988
1983 R65LS 1996 to present.
1984 R65LS 2019 to present.
spiney
YaBB Newbies
Reply #4 - 07/26/20 at 00:53:59
Kelvin unfortunately I have very little knowledge of the bikes history although pretty sure its only done 50,000K. Have not inspected the cam chain but it may be an idea. Far too wet today to have a ride and record the noise.
1981 r65
1976 90/6
spiney
YaBB Newbies
Reply #5 - 07/27/20 at 05:40:18
Took me a while but I put a video on u tube https://youtu.be/uJwQGamFL0Q
This is after a 15 min ride around the block.
1981 r65
1976 90/6
donbmw
Senior Member
Reply #6 - 07/27/20 at 09:40:58
Saw your post on Facebook. I didnít hear anything that sounds abnormal.
WWW
wilcom
Online
Reply #7 - 07/27/20 at 10:57:25
I hear the sound between 2-3000 but, like Don said,  it just sounds like normal Beemer stuff to me.
1979† R65† †
1980† R65† †† †† ††
1982 R80RT†
1974 R90/6††† †
1972† R75† †† †††
1964 R50
Bob_Roller
Global Moderator
† GMT -7 Hours
Reply #8 - 07/27/20 at 14:52:26
Do you have a mechanics stethoscope ??
You could try having someone else operate the throttle while you put the tip of the scope on various parts of the engine .
I listened to the video and did not hear anything out of the ordinary either .
You could check the exhaust system for looseness and fasteners in the area .
'82 R65 LS †
Kelvin
YaBB Newbies
R65LS
Reply #9 - 07/27/20 at 16:04:35
I also heard nothing out of the ordinary, so my hypothesis about the camchain is looking a bit weak.
In addition to checking the exhaust system you might check the air intake: you don't have a whistling cable in front of or leaf stuck inside the air intake horns?
tunnelrider
Senior Member
Reply #10 - 07/28/20 at 05:51:47
Had a look at the video - the whine sounds a bit different to me how it exists under no load - I do get a slight whine when attempting hard acceleration low down the revs under way, I always thought it must be the much read about induction 'roar' (I'd hardly call a roar).Kelvin wrote on 07/27/20 at 16:04:35:
Good point Kelvin I think I've always had a cable in front of the intake horns
'85 Black R65 / '74 GT185 / '83 Pantah 500 / '90 Super Tenere 750  / '01 DRZ400 dirt only
spiney
YaBB Newbies
Reply #11 - 07/28/20 at 15:56:20
Thanks for all the tips I will check everything suggested. I do have access to a mechanics stethoscope so will borrow it and see if I can zoom in a bit.
1981 r65
1976 90/6
Luca
YaBB Newbies
Reply #12 - 08/11/20 at 20:23:17
spiney wrote on 07/28/20 at 15:56:20:
often you can get away with just holding your ear to the handle of a long screwdriver and placing the business end at your inspection points.  I can hear a little bit of a whine, but nothing unusual.  It actually sounds pretty good to me!
