Welcome, Guest. Please Login or Register
YaBB - Yet another Bulletin Board
  Home R65 Wiki HelpSearchLoginRegister
Pages: 1 2
Send Topic Print
(Read 849 times)
MrRiden
R65LS Phoenix Arizona
Phoenix, AZ
Re: Calling all household electrical geniuses......
Reply #15 - 07/09/09 at 20:29:05
DeeG,
You mention a host of applications you would like to use the 12v for but I'm not so sure it would be a good idea. Many of the recharges you mention may very well be of application specific design and connecting a universal 12v supply to to your cell phone or gps may just void the warranty in a spectacular way. For running a 12v air pump or  firing up your Gerbings an outdoor light transformer [think Malibu lights] may be a good accessory. I Also like the overhead auto retracting cord reel. I'm remodeling the shop as well, some pegboard and also track lights from the recently remodeled kitchen are going up. Also looking for a small but good quality tunes box.
WWW
drewboid
Senior Member
Bergen County, NJ
Gender: male
Reply #16 - 07/10/09 at 07:40:27
Careful - The Malibu outdoor light transformer that I have is 12 volts AC!!!  It may work your Gerbings but it will damage your battery, air pump, and many other things. Come to think about it the Gerbings controller might not like it either!  YMMV
One way to add your 12V DC supply is to use an old 12V car or motorcycle battery - put it on a float charger and you should have a good stable source of 12V DC. Just make sure that the "old" battery still has some life left in it - don't use one with a bad cell.
Drew
R60/2 - LS200
R75/6
R65
R1100R
YaBB Administrator
I love my Beemers
Crowley, TX
Gender: male
Reply #17 - 07/10/09 at 11:51:27
The 12V requirements/uses will have to be well defined before any kind of recommendation could be made...
2004 BMW R1150RT-P
1982 R65LS - Project "Junkyard Dawg"
WWW
MrRiden
Phoenix, AZ
Reply #18 - 07/11/09 at 14:42:41
Good catch Drew. I just thought 12v & didn't realize my error. Forgetabout the Malibu lights thingie. Bad Idea.
WWW
ampliflyer
Senior Member
Lexington Kentucky
Gender: male
Reply #19 - 07/14/09 at 20:50:09
Just wire your garage to code with a few seperate 120v circuits and buy yourself a standard bench top 12 volt dc power supply many of which come with a built in car cigarette lighter jack on the front and you could use your car style chargers plugged into that...like this  :
http://www.autotoys.com/x/product.php?productid=7208
J_Hirst
Junior Member
Meine Klotz ist mein Freund
Roanoke, VA
Gender: male
Reply #20 - 07/15/09 at 10:33:49
OOH I like that table top converter.
Wish it also had a BMW plug on it.
Jonathan
1984 R65 "Blue" *Sold*
1990 K100LT "Das Klotz"
DeeG
Full Member
Central WA
Gender: female
Reply #21 - 07/18/09 at 02:10:29
After the electrical/radio genius at work overheard me chatting about wiring up the shop, he offered to come and help. Well, he offered to come over and teach me how to do it.  This guy wires up all our radio towers and everything associated with our comm center, and he built the two houses he has on his property, so I think I'm in good hands.  Which is probably just as well, as the spouse is thinking that maybe we should install a couple of them radiant heaters so we can work in the winter and not freeze to death.
He also pointed out a 12V converter box thingie he had on his workbench.  About $100.  The one that ampliflyer posted the link to would work just as well.....
MrRiden,  I've been wanting a radio/CD player for the shop as well.  I have a set of Altec Lansing computer type speakers set up in my kitchen. Fairly inexpensive (about $90) and it sounds really nice.  I'm going to use a Am/FM/CD player that I already have and just plug it into the speakers.  It also has a port for an MP3/sat radio as well.
The one in my kitchen is plugged into the Garmin GPS which has the XM puck on it.
Now I just have to wait for the temps to cool a bit before I start the project.  The shop temp was about 8 degrees warmer than the surface of the sun this afternoon. I had to wait until 10pm before it was tolerable to work in.
Dee G
1978 R45/N
1978 R80 w/hack
1971 R75 (swb)
wilcom
YaBB Newbies
198
Riverside, Ca
Gender: male
Reply #22 - 03/07/10 at 23:55:14
when I need 12v in the garage use a wall transformer , they are cheap. If ya need more ........ there's alwasy your batter charger!
Riverside, Ca
1999 Buell
1970 Imp Inca
Pages: 1 2
Send Topic Print
